OSD Plugin SDK
dippnsk
Hello everybody!
I'm new here and maybe don't know something really obvious, but where I can find a Plugin SDK or some kind of manuals to create my own OSD plugin (NOT A SKIN). I've found some old Delphi SDK's which is not covers any kind of OSD integration at all.
The OSD plugin must be visible as a custom menu item with custom content in DVBViewer OSD (is it even possible?).
Maybe there is a simple example of this?
Programming language: prefferable C++.
Thanks!
Link to comment
I think OSD plugins won't work in C++. Use delphi instead. In the second thread mague mentioned there was a strong discussion about this and we tried our best to get a OSD plugin in C++ running. One reason why we failed was the wrong call method in some functions of the OSD SDK (functions declared as stdcall but implemented as safecall). One can't fix this in C++ without (very) dirty tricks. User erwin explained this in more detail in one of the last posts in the thread.
Edited by dbraner
Link to comment
