jwplayer problem with RS
Hello i have problem i can't do live stream in jwplayer site it's says "Error loading player: No playable sources found"
Post a support.zip dose ...\DVBViewer\SVCweb\iphone\flowplayer exist on you system?
If not run the RS setup again.
I have tested all of this, only "Stream to the browser (needs Flash)" work in Jwplayer and Jwplayer working in PC only not IOS/Android
Edited by f00x
iOS and current Android versions don't have Flash so you cant use jwplayer there.
Ok, how can i do live stream via m3u in jwplayer i can't do live streams, but i tested m3u links from a website and it's works
i know someone do live stream in jwplayer with m3u and works very well in IOS & Android
Edited by f00x
The RS only uses the Flash player not the HTML5 player.
(this could be changed, but someone needs to spend the time to change files in SVCweb and in the ffmpegprefs.ini and provide this changes for integration in the RS. There is currently no web-interface developer)
For .m3u just open it in a media player e.g. VLC. At least on Android this works without problems.
Or use the app Android:
https://play.google.com/store/apps/details?id=org.DVBViewer.controller
https://github.com/RayBa82/DVBViewerController
http://www.DVBViewer.tv/forum/topic/55381-android-DVBViewer-controller/ (German)
iOS
http://www.DVBViewer.tv/forum/topic/56227-service-app-ios8/
