Tjod Posted February 13, 2016 Posted February 13, 2016 The DVBViewer and DVBViewer Media Server setup are using in many places default Inno Setup Translations. But some parts of the Texts are DVBViewer specific. If someone is interested in updating some translations here is file with the current translations DVBViewer Pro 6.0.3+ DMS 2.0.3+: English en. and German de. should be up-to-date. And therefore the best source for the translations. DVBViewer-DMS-setup-translations.txt 1 Quote
Residentcl Posted February 18, 2016 Posted February 18, 2016 One explanation for: en.ffmpeglicences=Show the FFmpeg licenses en.LaunchConfiguration=Launch Configuration If not too much to ask? Quote
Tjod Posted February 18, 2016 Author Posted February 18, 2016 It is on the last page of the RS setup. You can select them there. If FFmpeg was selected for downloading "Show the FFmpeg licenses" will open the folder with all the licenses of FFmpeg. And "Launch Configuration" will open svcoptions.exe Quote
Residentcl Posted February 18, 2016 Posted February 18, 2016 Ok Version 1.0 SP DVBViewer-RS-setup-translation.txt Quote
Gioxy Posted February 18, 2016 Posted February 18, 2016 Sorry but I'm unsure how/where send the tranlsation, so here it is only the Italian items: [CustomMessages] it.downloadffmpeg=Scarica FFmpeg versione {#FFmpegVersion} da http://ffmpeg.zeranoe.com/builds/ [CustomMessages] it.Datafolder=Cartella files Configurazione it.allusers=Per tutti gli Utenti (raccomandato) it.ProgramFolder=Cartella del programma it.peruser=Per ciascun Utente separatamente it.seldatalocation=Seleziona la Cartella files Configurazione it.wherestored=Dove salvo le impostazioni di DVBViewer? it.storedesc=Seleziona il tipo di installazione preferita. Se non si è sicuri selezionare "Per tutti gli Utenti". it.persinfo=Informazioni Personali it.checkkey=Controllo della Chiave di Registrazione it.autkey=Autorizzazione della Chiave di Registrazione per it.dwnerror1=Impossibile scaricare da Internet tutti i files! it.dwnerror2=Verificare la connessione ad Internet e/o i Dati Utente. it.dwnerror3=Puoi scaricare i files manualmente dalla Membersarea di DVBViewer. it.dvbvhelp=Documentazione di DVBViewer it.gdiperror1=File gdiplus.dll mancante! it.gdiperror2=Vuoi scaricarlo da Internet? it.downloadpg1=Pagina di Download dei Componenti Addizionali it.downloadpg2=Seleziona i Componenti Addizionali che ti interessa scaricare e installare, poi premi Next. it.complisterror1=Setup non può scaricare la lista dei Componenti Addizionali. Riprova in un altro momento o installali manualmente.%nSetup completerà comunque l'installazione normalmente. it.deletedata=Vuoi cancellare la Cartella dei Dati Utente? it.deleteprog=Vuoi cancellare completamente la Cartella di Programma di {#AppName}? it.keytoolfirst=Bisogna prima completare la registrazione con KeyTool.exe! it.Firewall=Crea una eccezione nel firewall di Windows per l'accesso dalla rete locale a DVBViewer. È necessaria quando DVBViewer viene utilizzato come client Sat>IP. it.Icons=Icone del programma: it.WindowsFirewallSettings=Impostazioni Windows Firewall: it.CreateStartmenuIcon=Aggiungi voci nel menu del pulsante Start ;RS it.FirewallRS=Sblocca l'accesso da LAN e WLAN nel firewall di Windows per il Recording Service. it.FirewallRSWeb=Sblocca l'accesso da Internet nel firewall di Windows per l'interfaccia web del Recording Service (porta 8089). it.selectdvbv=Bisogna selezionare la cartella di DVBViewer Pro! it.closedvbv=Per favore chiudi DVBViewer! it.firstdvbv=Bisogna prima aver installato DVBViewer Pro! it.checkpswd=Per favore controlla il nome Utenete e la Password! it.ffmpeglicences=Mostra la licenza di FFmpeg it.LaunchConfiguration=Avvia la Configurazione del Recording Service Quote
Tjod Posted February 18, 2016 Author Posted February 18, 2016 Thank you, they will be part of future setup. I have integrates them in the file in the first post. To have everything in one place. Quote
Residentcl Posted February 19, 2016 Posted February 19, 2016 Translation missing for DVBViewer? Quote
Tjod Posted February 19, 2016 Author Posted February 19, 2016 This topic is only about the setup. For translation of the DVBViewer or Recording Service use a different topic. The newest Spanish translation is there: http://www.DVBViewer.tv/forum/topic/22782-spanish-spain-language/#entry386654 If you run the DVBViewer in the Debung Mode (Start menu) you well get a configuration folder\Language\Missing_*.log with translations Strings which are missing in the selected language file. But for more questions use the topic of the Spanish language file or open a new one. Quote
drclone Posted June 4, 2016 Posted June 4, 2016 Hi, here is the last spanish language update for Recording Service setup: DVBViewer-RS-setup-translations.txt Quote
Tjod Posted June 4, 2016 Author Posted June 4, 2016 Thanks will be included in future set-up versions. Quote
AndreaB Posted August 30, 2017 Posted August 30, 2017 Here are the files for the Italian translation of Recording Service & Setup for DVBView 6.0.3. Ciao, Andrea DVB_Setup-6_0_3-IT.zip 1 Quote
Tjod Posted August 30, 2017 Author Posted August 30, 2017 Thanks it will be part of the setup of the next Version. Unfortunately the file in this topic wasn't completely up to date. But most of it are removed entries which aren't used in the set-up any more. Only "en.GroupExperts=Expert settings:" is missing in your translation compared to the current version. I have updated the file in the first post. Quote
AndreaB Posted September 2, 2017 Posted September 2, 2017 Here the translation: it.GroupExperts=Configurazione avanzata: But is there a repository where I can take the updated file? Ciao, Andrea Quote
Tjod Posted September 2, 2017 Author Posted September 2, 2017 No, there is no repository with the setup scrips. Quote
AndreaB Posted July 3, 2018 Posted July 3, 2018 On 2/13/2016 at 3:45 AM, Tjod said: But some parts of the Texts are DVBViewer specific. If someone is interested in updating some translations here is file with the current translations DVBViewer Pro 6.0.3+ DMS 2.0.3+: DVBViewer-DMS-setup-translations.txt In the Italian version I saw that I have some sentences no longer present in the English version: do I have to remove they because they are obsolete? Quote
AndreaB Posted December 29, 2025 Posted December 29, 2025 Hi, I hope this is still the correct topic for the Setup translation. As you can see, there's a new English sentence in the Setup, but I'm not sure how to pass the translation on to you. The translation is: "Abilita DVBViewer al supporto della TV multicast su Internet." If you need it in any other format, let me know. Ciao, Andrea Quote
Griga Posted December 31, 2025 Posted December 31, 2025 Am 29.12.2025 um 20:37 schrieb AndreaB: As you can see, there's a new English sentence in the Setup Thanks for looking after it. I've integrated the Italian translation of the new sentence in the setup language file - see attached custlanguages.txt, section containing entries starting with it. This file is used by the setup builder, which means, the language entries get hard-coded in the setup.exe. They are not read from an external file while the setup is executed. custlanguages.txt Quote
AndreaB Posted January 1 Posted January 1 Hi Griga, With this file, I realized that other translations were missing, and I fixed some others: here it is, updated for the Italian part. Happy New Year!😄 Ciao, Andrea DVBViewer-RS-setup-translations-IT.txt 1 Quote
Griga Posted January 1 Posted January 1 Thanks. I wish we had this support for all languages... BTW: The file is used for the Media Server and DVBViewer setup. Quote
Griga Posted January 1 Posted January 1 Sorry, but it doesn't work this way. Entries prefixed with "it." are Italian. Serbian Latin doesn't seem to be supported by the DVBViewer/DMS setup (yet). The available language definitions I can see are the following: Spoiler [Languages] Name: en; MessagesFile: compiler:default.isl Name: fr; MessagesFile: compiler:Languages\french.isl Name: de; MessagesFile: compiler:Languages\german.isl Name: pl; MessagesFile: compiler:Languages\polish.isl Name: ru; MessagesFile: compiler:Languages\russian.isl Name: du; MessagesFile: compiler:Languages\dutch.isl Name: it; MessagesFile: compiler:Languages\italian.isl Name: fi; MessagesFile: compiler:Languages\finnish.isl Name: hu; MessagesFile: compiler:Languages\hungarian.isl Name: sp; MessagesFile: compiler:Languages\spanish.isl Name: cz; MessagesFile: compiler:Languages\Czech.isl Name: dk; MessagesFile: compiler:Languages\Danish.isl Name: no; MessagesFile: compiler:Languages\Norwegian.isl Name: pu; MessagesFile: compiler:Languages\Portuguese.isl Name: slk; MessagesFile: compiler:Languages\Slovak.isl Name: sw; MessagesFile: compiler:Languages\Swedish.isl I first have to find out more about how the language support is working... Quote
