Motorcycleboy
Where can we download old versions of DVBViewer?
Motorcycleboy
Old versions of DVBViewer are not available in the members area and the announcements of new versions in the forum only provide a link to the members area.  I have tried trustworthy sites that might archive the old versions like videohelp.com and afterdawn.com, but with no success.  Google searches for DVBViewer with a version number bring up cracked and repacked versions or demos.  What is someone to do if they try the latest version and they do not like it, but they foolishly deleted the installer for the version they had been using from their pen drive?  In my case I have been using version 5.2.9.0 without any problems at all, but I would like to explore possible improvements in later versions, but the latest version sets the aspect ratio and full screen differently which seems less satisfactory to me.
Share this post
Link to post
Tjod
If you don't have the old setup on your PC e.g. in a backup (they are stored in /DVBViewer/setup/ as long as you aren't uninstalling them or delete the folder).
And if the developer decided to not make it available in the members area. Then there is no way for you to get a old version.
The members area is the only legal way to get the DVBViewer Pro. And a 5.2.9.0 setup downloaded by someone else would not work with your licence data.
(And would result in a permanent ban (members area and forum) for the person providing the version)
Share this post
Link to post
Tjod
vor 45 Minuten schrieb Motorcycleboy:
I don't know what you are talking about.
Share this post
Link to post
Mr Jolly
Waste of time, I've taken a trip down memory late tonight trying all my downloaded versions of DVBViewer. My earliest version is 4.1 and I have versions through to 5.6.4. anything in the v4 era is erroring with incorrect keytool.exe data. I have meticulous records and know my license info is correct.
Share this post
Link to post
Motorcycleboy
Thanks for your reply Tjod.  I had not anticipated that each copy of DVBViewer downloaded from the members area is personalized for each member.  In future I shall be vigilant in archiving each version of DVBViewer as they are released because the developer does not want to offer old versions to members.
Share this post
Link to post
quack
At least it would be very nice to be able to download the previous release from the member zone.
ie version n and version n-1
Share this post
Link to post
HaraldL
Have you looked into your installation dir (mostly C:\Program Files (x86)\DVBViewer\Setup) as Tjod already wrote in Post #2 two years ago? As long as you not delete the content or format your drive there you will find all your previous (personalized) setup packages of DVBViewer or RS/DMS you ever installed. I personally back up them additionally on an external drive too.
As there is no auto-update and you have to download each build manually why delete the older ones and not keep them?
Share this post
Link to post
quack
yes but I missed version 6.1.4 and would like to add it to my collection and I can't now that version 6.1.5 is released
That's why if we could at least download the previously released version in addition to the latest one it would be nice
Anyway what's the point in preventing supporting members to download previously released versions ?
Edited by quack
Share this post
Link to post
Griga
Version 6.1.4 is still available in the "Older Versions" section of the customer download area. Scroll down to the bottom...
Share this post
Link to post
quack
Thank you. I don't know how I missed it yesterday...
Maybe because it's called "DVBViewer" and not "DVBViewer Pro", but it is indeed the pro version
Edited by quack
Share this post
Link to post
  • Similar Content
    • Hunter77
      By Hunter77
      I've recently installed the latest version of DVBViewer, but when I try to play old mpg recordings (recorder with a very old version of DVBViewer) most of them freezes; on the ones that don't freeze is not possible to jump forward or back.
      I've noticed that I have not the same problem with .ts files (old and new) nor with mpg recordings made with current version of the program.
      I have tried playing a bit with codecs but I can't see any improvements (now I'm using ffdshow codec).
      Any idea?
