mezzy Posted August 12, 2018 Posted August 12, 2018 (edited) Hi Can i suggest to have a http playlist links for recordings like tv-playlist in DMS for next update and want to know if it will be possible to add TS-stream with mpeg-dash ( need french ip to play ) https://hdfauthftv-a.akamaihd.net/esi/TA?format=json&url=https://livefrancetv.akamaized.net/simulcast/France_2/dash/France_2.mpd&callback=_jsonp_loader_callback_request_0 or this link below http://hdfauthftv-a.akamaihd.net/esi/TA?format=json&url=http://live.francetv.fr/simulcast/France_2/hls_v1/index.m3u8 It will be much appreciated thanks in advance Edited August 12, 2018 by mezzy forgot links Quote
Griga Posted August 12, 2018 Posted August 12, 2018 1 hour ago, mezzy said: Can i suggest to have a http playlist links for recordings like tv-playlist in DMS for next update Don't know what you mean. Please explain in more detail. 1 hour ago, mezzy said: and want to know if it will be possible to add TS-stream with mpeg-dash MPEG Dash is not supported yet. It is under development, but will take some time. 1 hour ago, mezzy said: or this link below HLS (.m3u8) works in DVBViewer and DMS within the "TS Stream" reception type framework. Read more about it here - third point from the top (Channel List) and the Streaming & Channel Handling sections. Quote
mezzy Posted August 13, 2018 Author Posted August 13, 2018 (edited) first point : in DMS interface we have links section which give http channels list or rtsp or transcoded m3u8 file can i suggest to have the same for recordings? with the log created perhaps the list could have recording name in m3u list #EXTINF:0, "Channel name" - "program name" http:127.0.0.1:8089/stream/recording1.m3u8 #EXTINF:0, "channel name" - "program name" http://127.0.0.1:8089/stream/recording2.m3u ps: sorry for my poor english... thanks Edited August 13, 2018 by mezzy forgot links Quote
Griga Posted August 13, 2018 Posted August 13, 2018 7 minutes ago, mezzy said: can i suggest to have the same for recordings? Web Interface -> Media page -> Recordings -> Click the "Create Playlist" icon ▼(appears on mouse over) on the left side of folder names to download the folder content as M3U. Quote
mezzy Posted September 9, 2018 Author Posted September 9, 2018 i want to know why we cannot have full recordings playlist transcoded ? it is only possible for each episodes separately thanks for reply Quote
Hansrh Posted September 9, 2018 Posted September 9, 2018 (edited) On 8/13/2018 at 7:31 AM, Griga said: Web Interface -> Media page -> Recordings -> Click the "Create Playlist" icon ▼(appears on mouse over) on the left side of folder names to download the folder content as M3U. Hm - I don't seem to find the icon "Create Playlist" ? Edited September 9, 2018 by Hansrh Quote
Griga Posted September 9, 2018 Posted September 9, 2018 4 hours ago, mezzy said: i want to know why we cannot have full recordings playlist transcoded ? Because transcoding is mostly needed for playback in browsers. They are not able to handle playlists. And there is a drawback: Since the Media Server transcodes on the fly while sending the stream, players usually regard the result as live stream, because they get no file size. That's why seeking / jumping is not possible. The only exception is HLS as target format because of segmentation. However, you can create such a playlist manually by using a text editor. Compare a playlist for untranscoded playback with the single entry for transcoded playback (example): Untranscoded: #EXTINF:2153,The One Showhttp://127.0.0.1:8090/upnp/recordings/00030.ts Transcoded: #EXTINF:2153,The One Showhttp://127.0.0.1:8089/flashstream/stream.webm?preset=WebM%20High%201800%20kbit&ffpreset=superfast&recid=30 In the M3U list for untranscoded playback first search and replace the blue part by the blue part for transcoded playback. Then search & replace the red part by an empty string (thus deleting it). The leading zeros don't matter. Quote
Hansrh Posted September 9, 2018 Posted September 9, 2018 1 hour ago, Hansrh said: Hm - I don't seem to find the icon "Create Playlist" ? Correction - I found the icon ? Quote
