henrix Posted September 18, 2018 Posted September 18, 2018 Hi I using MediaS for streaming to pc with Kodi. But my problem is How can I use plugins on MediaServer? I'm using DVBViewer with plugins for watch sateliite TV. And how can I configure MS for using plugins. It is possible using plugins on MS? Thnak you for answer Quote
Griga Posted September 19, 2018 Posted September 19, 2018 http://en.dvbviewer.tv/wiki/Plugins_and_Recording_Service Quote
henrix Posted September 21, 2018 Author Posted September 21, 2018 Hi I bought latest version MS and I crate folder Plugins1. But in Kodi i have only black screen. But where can I find log which plugins is loaded over MS? Thank you Quote
Griga Posted September 21, 2018 Posted September 21, 2018 The DMS writes to the file svcdebug.log (see configuration folder) how many plugins have been found, but not which ones. Quote
henrix Posted October 13, 2018 Author Posted October 13, 2018 Hi I reinstalled Windows 10 and installed driver for DigitalDevices , DVBViewer and mediaServer. My configuration is 2 LNB (one is double on 23,5Astra and one signle on Hotbird) and Diseqc 2.0 switch ( one wire from Hotbird and one wire from Astra) DVBViewer settings is Tuner1 has group A,B and Tuner2 has group A. And I have still two problems: First: On DVBViewer Picture in Picture is not working. If I turnON PiP and change channel Pip is turnOff. but this is doing only for some channel I dont know why. But I need watch channel in PiP from Astra and this is not working. Second:MS is not streaming any channels. If I open WebInterface and I choose channel streaming is NOT WORKING in browser,vlc player kodi. Can you help me pls resolve this problem? Thank you Ps: In PiP mode it is possible change channel from Favorites list? Quote
Griga Posted October 13, 2018 Posted October 13, 2018 50 minutes ago, henrix said: First: On DVBViewer Picture in Picture is not working. If I turnON PiP and change channel Pip is turnOff. but this is doing only for some channel I dont know why. PiP is turned off if there is no second tuner for the new channel. The main video window has priority. Different channels on the same frequency work with only one tuner in the main video window and PiP. 52 minutes ago, henrix said: Ps: In PiP mode it is possible change channel from Favorites list? Right-click a channel in the channel list window -> Picture in Picture. If the PiP menu item is grayed, there is no free tuner available for it. Quote
henrix Posted October 13, 2018 Author Posted October 13, 2018 I dont understand your answer. I have 2 tuners and I want watch one channel on main window and one in PiP window. both channels is from Astra and I have double LNB on Astra. It is possible? How? And MediaServer not streaming any channels its feature or what is problem? Thank you Quote
Griga Posted October 13, 2018 Posted October 13, 2018 Maybe something is wrong with your configuration. I have a similar setup (one LNB for Astra 19°E, one for Astra 19°/23°/28°E and Hotbird). The first LNB is connected to a tuner that is configured for channel group A only, the second LNB is connected to a tuner that is configured for channel group A and B. All Astra 19°E channels belong to channel group A, all Astra 23°/28° and Hotbird channels belong to channel group B (configured in the channel editor). Watching two Astra 19°E channels from different frequencies in the main video window and PiP of DVBViewer 6.1.2 works. Attaching a support.zip could help... Quote
Griga Posted October 14, 2018 Posted October 14, 2018 Your configuration is wrong. DVBViewer is not configured for sharing DVB hardware with the Media Server. DVBViewer must not use the Digital Devices tuners directly. It must work as Media Server client and use virtual RTSP network devices for connecting to the Media Server. Only the Media Server should use the Digital Devices tuners directly. Please perform Help -> Media Server Wizard in DVBViewer. Additionally you need to configure the channel groups in the Media Server Options (svcoptions.exe) -> Hardware. Quote
henrix Posted October 15, 2018 Author Posted October 15, 2018 Hello Griga Thank you for answer but I run several times MediaServerWizard in DVBViewer and nothing happened.I have to reinstall MediaServer.(but context menu is still same like on image from logs.) I save new log on same url like I sent to you yesterday. I saw RTSP but PiP not working and stream too. Can you check new log please? Thank you Quote
Griga Posted October 16, 2018 Posted October 16, 2018 17 hours ago, henrix said: context menu is still same like on image from logs. I have just checked it under Windows 10 with 150% text size and Czech language, but here it is displayed normally. Maybe the Czech language file is damaged on your PC. For a test please rename the file rc_czech.lng in C:\Program Files (x86)\DVBViewer\Language to rc_czech.txt. Then close the Media Server tray tool that displays the context menu ( C:\Program Files (x86)\DVBViewer\DVBVCtrl.exe). If you cannot close it with the context menu (last item -> Ukončit program), use the windows task manager to finish DVBVCtrl.exe. Then start it again. The menu should now be displayed in English. Is it ok now? Quote
henrix Posted October 16, 2018 Author Posted October 16, 2018 Hi Context menu is now working. thank you. Do you check new logs? Becasue actually Pip and stream are still not working. Quote
Griga Posted October 17, 2018 Posted October 17, 2018 On 10/15/2018 at 6:39 PM, henrix said: I save new log on same url No good idea because the browser gives me the old files from its cache. I cannot get the new files without clearing the cache or using another browser. 9 hours ago, henrix said: Do you check new logs? Your hardware setup seems to be ok now. DVBViewer is configured as DMS client. Does it work? Can you watch TV in DVBViewer as expected? Quote
henrix Posted October 17, 2018 Author Posted October 17, 2018 (edited) New logs is on url. PiP is not working. If i change channel PiP is close or Pip is frozen after change main channel. Thank you Edited October 17, 2018 by henrix Quote
Griga Posted October 18, 2018 Posted October 18, 2018 Does it work with unencrypted (free) channels? Maybe decryption and the way you have set it up causes the problem. Quote
henrix Posted October 18, 2018 Author Posted October 18, 2018 Yes free channel is working in webBrowser player(vlc player too) but only if DVBViewer is turned off. But crypted is not working always (I have plugins1 and plugins2 in DVBViewer\plugins) Quote
Griga Posted October 19, 2018 Posted October 19, 2018 Sorry, decrypting with plugins is not supported here. It is illegal in Germany and discussions about it forbidden by the forum rules §13. You must find the information that you need somewhere else. Quote
henrix Posted October 20, 2018 Author Posted October 20, 2018 OK..but DVBViewer supports decrypting channels with plugins. But streaming is not working with free channels too. And PiP in DVBViewer is not working too - doesnt' matter if it is free or decrypted channels. So I will ask you to refund me money for MediaServer becasue MediaServer is for me useless. Thank you. Quote
Griga Posted October 20, 2018 Posted October 20, 2018 On 10/18/2018 at 7:05 PM, henrix said: Yes free channel is working in webBrowser player(vlc player too) but only if DVBViewer is turned off. Looks like your second tuner is not working or gets no signal. For a test you can set the status of the first tuner in the DMS Options -> Hardware to "Do not use". Quote
henrix Posted October 21, 2018 Author Posted October 21, 2018 M configuration: Tuner(1) - astra 23.5 , hotbird (group A,B) Tuner(2) - astra 23.5 (group A) 1) Tuner(1) = Off,Tuner(2) = On Astra23.5 - working Hotbird - not working 2) Tuner(1) = On,Tuner(2) = Off Astra 23.5 - working Hotbird - working 3) Tuner(1) = ON Tuner(2) = On I turn ON PiP = main Window(free channel on astra 23.5) and Pip window(free channel astra 23.5) same channel If I changed channel in main window(other free channel astra 23.5) then Pip window automatic close. It is possible to make PiP work? Quote
