oshertw Posted January 22, 2020 Posted January 22, 2020 Hello, My name is Osher and I've just purchased your software with license. I am trying to play UDP link and I can't see video. while inserting the URL link I get the following error: "DVBViewe Pro Error - Cannot render Mediafile/Output pin, error: 0x800C00D the specified protocol is unknown." The url link I am using is: udp://233.1.4.1:2004 This is internal URL and I am in the same network. By the way - in VLC i can play it successfully. I am not sure how to run multicast, could you please help me with this issue? If this is not possible so please refund me - this software is not suitble for my needs. Thanks; Osher. Quote
Griga Posted January 22, 2020 Posted January 22, 2020 3 hours ago, oshertw said: while inserting the URL link Where? Quote
oshertw Posted January 23, 2020 Author Posted January 23, 2020 In the software there is option : Playback>URL but i get this error message. is there any way to add multicast Address and see the video stream? Quote
Griga Posted January 23, 2020 Posted January 23, 2020 What's inside the UDP stream? If it is a transport stream, you can add it as channel in the channel editor: Select TV/Radio -> Channel Editor Select the category folder in the channel list where the new channel shall be stored. Click the New Button on the right side -> TS Stream Enter the address and the channel name in the blank form and click Add. DVBViewer will retrieve the rest of the channel data on first tuning. Double-click the new channel for playing it. Read more about the TS Stream reception type in the Streaming Section here. Quote
