jampeer
Version 6.1.6.0 problem with IPTV.
jampeer
Hello. After upgrading to Version 6.1.6.0, the IPTV channels of some providers do not work.
After rolling back to the previous version, everything will work again.
What were the changes and where to look for a solution?
Thanks.
Share this post
Link to post
Griga
What does not work with which IPTV type? Be more specific or forget it...
See DVBViewer -> Help Menu -> Change Log.
  • Like 1
Share this post
Link to post
jampeer
Clarification.
The IPTV provider has channels on different servers.
On the new version, only channels from the server on which the client is located work, and channels from other servers do not work.
It turns out that the forwarding has stopped working, if I'm not mistaken.
On previous versions there is no such problem.
Share this post
Link to post
jampeer
Maybe I’m not completely clear, I apologize. I use a translator.
The problem is that in the new version only channels from the server on which you are located work.
That is, if you are allowed on the 2nd server, then only the channels from the second server work,
if you go to the third server, then the channels that are located on the third server begin to work.
And those that worked before this stop working. I repeat, if, for example, return to version 1.6.4.0 then everything works.
Edited by jampeer
Share this post
Link to post
jampeer
Same problem on DVBViewer Test Version 6.1.6.1
Share this post
Link to post
jampeer
Hey.
Can I get information paid attention to this problem?
Thanks.
Share this post
Link to post
Griga
Tells me nothing. What type of IPTV? How do the URLs look like? Post an example and make the parts that you don't want to become public unrecognizable.
  • Like 1
Share this post
Link to post
jampeer
Maybe throw in your personal test playlist for verification?
Share this post
Link to post
jampeer
Sent in PM, please see the message.
Share this post
Link to post
Griga
OK, the protocol ist HTTPS and the IPTV type is HLS (with .m3u8 file extension). That enabled to spot the problem.
I've re-uploaded the DVBViewer Pro 6.1.6.1 test version in the download area -> beta section. Please try...
  • Like 1
Share this post
Link to post
jampeer
Yes, in the test version everything works as before.
Thanks.
Share this post
Link to post
swordoski
I have the same problem with 6.1.6.1. 😥
I can´t start or change channel through my channel list.
But if i copy and paste the URL from the channel list and use "playback url" it works
Any tips ?!
Share this post
Link to post
Griga
You don't. If you had exactly the same problem, it would work with version 6.1.6.1.
Probably the format is not suitable for the TS Stream reception type. Read more about it here in the Streaming section.
Any tips ?!
Almost impossible because you provide very little information.
Share this post
Link to post
swordoski
Mayby that not the hold truth 😶
However, the channel list has stopped working quite suddenly so I upgraded to 6.1.6.1 but still have problems.
Do you think I need to clear channel.dat or channel.ini ?!
I load the channellist from  *.m3u file
URL is
http: //xxx.yyy.zzz:1111/aaaa/bbbb/111
Share this post
Link to post
swordoski
URL is
Uninstall the program.
Remove files under C:\ProgramData\CMUV\DVBViewer.
Remove entires of DVBViewer in registry.
Reinstall the program
Load new and smaller IPTV.m3u list.
But still can´t change channel from channel list......
Share this post
Link to post
