McenterFreak Posted March 12, 2020 Posted March 12, 2020 My DVB Media Server motherboard decided to die. Installed new motherbord with new SSD. Moved image from old SSD to new SSD Windows 10 and everything works fine But DVB Media Server and DVBViewer dosent work, no picture and no sound on clients Decided to concentrate on getting DVBViewer to work on server Stopped Media Server Installed newest version of DVBViewer Checked that all 4 DVB S2 tuners was reconised But still no picture support with only DVBViewer running.zip Quote
Griga Posted March 12, 2020 Posted March 12, 2020 There is no DVBViewer.log in your support.zip, because you didn't reproduce the problem in DBViewer debug mode (see here), so there is important information missing. However, I can see that you are using Digital Devices driver 3.0.0.195. Some time ago German users reported trouble with it (see here) - the driver delivered no data to applications. It was solved by returning to version 2.6.5.142. Another topic dealing with version 3.0.0.195 can be found here. Quote
McenterFreak Posted March 12, 2020 Author Posted March 12, 2020 Atached support.zip from DVBViewer debug mode Can't understand it should be a driver problem, because it has not been changed since 2018 Can you see anything in support.zip? support.zip Quote
Griga Posted March 12, 2020 Posted March 12, 2020 58 minutes ago, McenterFreak said: Can you see anything in support.zip? No DVBViewer error to be seen. I'm sure you will see "no data" on the DVBViewer Filter property page (Settings -> Filters -> DVB Source), which means, no data is coming from the driver. 59 minutes ago, McenterFreak said: Can't understand it should be a driver problem, because it has not been changed since 2018 You've changed the mainboard. Is it the same as before? Quote
McenterFreak Posted March 12, 2020 Author Posted March 12, 2020 18 minutes ago, Griga said: No DVBViewer error to be seen. I'm sure you will see "no data" on the DVBViewer Filter property page (Settings -> Filters -> DVB Source), which means, no data is coming from the driver. You've changed the mainboard. Is it the same as before? It is not the same mainboard, but the same image. I was lucky it worked fine with the image from the old mainboard. I will try with the driver you mentioned Quote
McenterFreak Posted March 12, 2020 Author Posted March 12, 2020 Found the reason! First of all, it was not possible to "downgrade" the Digital Devices drivers. Installation just aborted with the reason that a newer version was installed Then i installed the newest version, still no luck I then tried the DD Controlcenter, and found that the binding between the CAM and the 4 tuners was unchecked. Checked them, and all works fine now:-) Quote
