الهاوي Posted August 5 Posted August 5 How to activate timeshift in DVBViewer and recording https://imagetourls.com/en/v?u=https%3A%2F%2Fcdn.imagetourls.com%2Fuploads%2FtyImg%2F10R8UlKLb.png Quote
Webturtle Posted August 5 Posted August 5 Hello, look here: https://www.DVBViewer.tv/forum/topic/64626-DVBViewer-700/#0.5.Timeshift|outline Many greetings Webturtle Quote
الهاوي Posted August 5 Author Posted August 5 Thank you, Professor: you expanded the topic, the topic is two words. I don't know German or English, I use a translator to communicate with you... That's why the shorter the words, the better. Quote
Griga Posted August 6 Posted August 6 Red: Start/stop normal recording Yellow: Start/stop timeshift recording Normal and timeshift recording are the same. The only difference is that DVBViewer deletes timeshift recordings automatically when you change the channel or close DVBViewer. But it does not delete normal recordings. TV/Radio -> Keep Timeshift File switches between normal recording <--> timeshift recording. TV/Radio -> Record Current Channel or the red record button start/stop a normal recording. TV/Radio -> Timeshift starts/stops a timershift recording without pausing playback. A timeshift recording enables jumping back in time and playing something again that you have missed in live TV. This also works with a normal recording. Pause button: Starts a timeshift recording, if no recording is going on yet, and pauses playback. You can continue playback later with the Play button at the point where you have clicked Pause. Example: You are watching a TV show. Suddenly the telephone rings, and you have to answer the call. You click the Pause button. DVBViewer pauses playback and starts a timeshift recording of the show. After the telephone call is finished, you click the Play button and continue to watch the show without missing something, because DVBViewer now plays the timeshift recording, not live TV. If you change to a different channel or close DSVBViewer, after you have watched the show, DVBViewer automatically deletes the timeshift recording. Quote
الهاوي Posted August 6 Author Posted August 6 18 hours ago, Griga said: الأحمر: بدء وإيقاف التسجيل العادي الأصفر: تسجيل التبديل المؤقت ببدء وإيقاف التسجيل العادي والتسجيل في التغير الزمني متشابه. الفرق الوحيد هو أن DVBViewer يحذف تسجيلات التغير الزمني تلقائيا عند تغيير القناة أو إغلاق DVBViewer. لكنه لا يحذف التسجيلات العادية. TV/Radio -> يحتفظ بملفات Timeshift بين التسجيل العادي < تسجيل > Timeshift. التلفزيون/الراديو - > تسجيل القناة الحالية أو زر التسجيل الأحمر يبدأ/يوقف التسجيل العادي. التلفزيون/الراديو - > يبدأ أو يوقف Timeshift تسجيل Timershift دون إيقاف التشغيل مؤقتا. تسجيل Timeshift يتيح لك القفز بالزمن وتشغيل شيء فاتك مرة أخرى في التلفزيون المباشر. وهذا يعمل أيضا مع التسجيل العادي. زر الإيقاف المؤقت: يبدأ تسجيل Timeshift إذا لم يكن هناك تسجيل بعد، ويوقف التشغيل مؤقتا. يمكنك متابعة التشغيل لاحقا باستخدام زر التشغيل عند النقطة التي ضغطت فيها على إيقاف مؤقت. مثال: أنت تشاهد برنامجا تلفزيونيا. فجأة يرن الهاتف، وعليك الرد على المكالمة. تضغط على زر الإيقاف المؤقت. توقف DVBiwer عن التشغيل وبدأ تسجيل البرنامج بنظام التغير الزمني. بعد انتهاء المكالمة الهاتفية، تضغط على زر التشغيل وتستمر في مشاهدة البرنامج دون أن تفوت شيئا، لأن DVBiewer الآن يشغل تسجيل Timeshift، وليس التلفزيون المباشر. إذا غيرت قناة أخرى أو أغلقت DSVBviver، بعد مشاهدة البرنامج، يقوم DVBiewer تلقائيا بحذف تسجيل التغير الزمني. Thanks... got it and understood... The picture explains everything... Thanks again Quote
