Media server stops working silently
Alan_SP
Hi Griga.
I have mentioned it before, but now I have decided to report it officially.
My Media server fails silently, I do see it "working" (blue icon), but when trying to connect to it, or record something, nothing happens. If it's just connecting to it with browser, no too big of an issue, I just stop and then start again media server on my HTPC and then it works again. Bigger issue is that my recordings fail too, for obvious reasons as server is down.
Before on my old PC, I remember DVB working for months and months. Now, it's maybe a week.
Please see if you can see what is causing the issue. It might be my PC, not sure. I keep it running, it shouldn't go to sleep, hibernate or anything similar. It just seems that media server fails silently.
Your video database (svcmediaVideo.db3) seems to be corrupted, which causes a lot of access violations. Please do the following:
  • Stop the Media Server.
  • Remove the file svcmediaVideo.db3 from the Database subdirectory of the DVBViewer configuration folder (see Help Menu in DVBViewer).
  • Start the Media Server (recreates svcmediaVideo.db3 automatically).
  • Go to the Tasks Page of the Web Interface and update the video database.
Additionally I recommend to update to the current DVBViewer 7.3.3 / Media Server 3.3.3 versions.
Thanks, I have removed and then updated database.
I also updated to the latest version. I have done that yesterday, I just wanted to send support file with info when I'm sure the fail happened.
I'll report later in case if it fails again. Or, if it's fixed. My guess is, when I was installing DVBViewer on this new HTPC, I copied config folder from the old machine and somewhere in the process it got corrupted.
