markymark Posted October 24, 2007 Author Posted October 24, 2007 Hi markymark, any updates on this? Yep. Ill fix it as soon as my job and family leaves me the time. This is likely to be in November Quote
luggi44 Posted October 31, 2007 Posted October 31, 2007 Hi! Very nice software! Is there any possibility to make it work with DVBViewer GE? Greetings, Ludwig Quote
marttil7 Posted November 2, 2007 Posted November 2, 2007 At first thanks a lot for this plugin! It's just great. Still I have one problem with plugin. I think mostly because I don't understand german, so I would be glad if someone who can could help me. Is there any setting that would disable disk space monitoring? Is it possible that VFD shows just DVBViewer information? I think quite a many users could use translation for plugin settings (prefer english). It's not even necessary that translation is exactly corret I just don't understand any of settings... Cheers marttil7 Quote
Moses Posted November 3, 2007 Posted November 3, 2007 you should enable in iMon Manager that 3rd party applications use iMon. It's somewhere in the options. Then the iMon Manager software won't show anything on the vfd and the plugin can handle it completely. Quote
Dirk Pit Posted November 8, 2007 Posted November 8, 2007 (edited) Hallo , kann einer den Plugin noch eimal uploaden . Die Links sind Down . Mfg PS jetzt ging es !! Edited November 8, 2007 by Dirk Pit Quote
six3323 Posted November 14, 2007 Posted November 14, 2007 Der letzte Link auf Seite 3 ging bei mir Problemlos. Allerdings bekomme ich das PlugIn nicht zum Laufen. IMONPlugin.exe und SG_VFD.dll Beide Dateien hab ich ins DVBViewer/Plugin Verzeichnis kopiert. Die IMONPlugin.exe kann ich auch starten und sie erkennt auch das iMON VFD laut PlugIn Anzeige (allerdings nur wenn der iMON-Manager vorher beendet wird oder auf Third-Party-Programme eingestellt wird). Auf dem VFD meines Silverstone GD01MX bekomme ich allerdings nichts angezeigt. In der Software IMONPlugin.exe sehe ich den Programmnamen etc. auf dem "Simulierten VFD. Habs auch schon mit und ohne der Third-Party-Software-Einstellung im iMON-Manager versucht. Leider immer ohne Erfolg. Kann vielleicht jemand ne detailierte Anleitung posten bzw. mir bei dem Problem weiter helfen ? Grüße Markus Quote
markymark Posted November 15, 2007 Author Posted November 15, 2007 (edited) At first thanks a lot for this plugin! It's just great. Still I have one problem with plugin. I think mostly because I don't understand german, so I would be glad if someone who can could help me. Is there any setting that would disable disk space monitoring? Is it possible that VFD shows just DVBViewer information? I think quite a many users could use translation for plugin settings (prefer english). It's not even necessary that translation is exactly corret I just don't understand any of settings... Cheers marttil7 Just set "Anzeigeschwellwert" to zero. it is the threshold for displaying the warning (given in true gigabytes). Edited November 19, 2007 by markymark Quote
markymark Posted November 15, 2007 Author Posted November 15, 2007 Hi, theres a problem with the font-encoding on my iMon, too. If I select 'Anzeigetest' in your plugin, the displayed chars do not match the ones actually shown on the iMon display. For example, if 'Zeige Zeichen ab Code 64' is selected, your plugin shows a '\' in the lower row, 4th element from the right, but the iMon display shows an '¥'. The VFD-Test Plugin from Lars works without font-encoding problems, so maybe you could take a look at his code to find out where the difference is. cheers, Thorsten HI, can you (or someone else) please compare that to the charset shown on http://www.noritake-itron.com/SubPages/App...sE/vfmodapn.htm to check if THAT is the charset employed by the display? That would be pretty helpful Quote
Warp10 Posted November 17, 2007 Posted November 17, 2007 HI, can you (or someone else) please compare that to the charset shown on http://www.noritake-itron.com/SubPages/App...sE/vfmodapn.htm to check if THAT is the charset employed by the display? That would be pretty helpful Hi, yes that is the charset employed by the display. cheers, Thorsten Quote
markymark Posted November 18, 2007 Author Posted November 18, 2007 Hi, yes that is the charset employed by the display. cheers, Thorsten Okay, I will add support for that with the next release. Quote
Warp10 Posted November 19, 2007 Posted November 19, 2007 Okay, I will add support for that with the next release. Great! Thanks in advance! Quote
markymark Posted November 19, 2007 Author Posted November 19, 2007 (edited) EDIT: Updated files (localization files where missing) -- NEW RELEASE 0.90 --- This new release adds - support for CU-U Charset VFDs (experimental, please check and report) - support for localization (english and german included) WBR MarkyMark imonplugin_090b.zip Edited November 19, 2007 by markymark Quote
more10 Posted November 19, 2007 Posted November 19, 2007 Hi I got an iMON OEM LCD installed in my Silverstone Grandia. The plugin says "Kein IMON VFD gefunden", it cannot find an IMON . Quote
markymark Posted November 19, 2007 Author Posted November 19, 2007 Hi I got an iMON OEM LCD installed in my Silverstone Grandia. The plugin says "Kein IMON VFD gefunden", it cannot find an IMON . Sorry, this plugin currently only supports the iMON VFD display, but NOT the new iMON LCD. However, this may change in the future given that someone posted here some information that seems to be sufficient to support ist. Still, I will not buy the display because I already own 3 (!) iMON VFDs and my wife is going to kill me if I buy another Thus, support for the new display will be added rather slowly (if at all). Quote
marc88 Posted November 21, 2007 Posted November 21, 2007 first i wanna thank you for this wonderful plugin which (almost) does everything i need my vfd for... my only question is wether you could add an option to display date/time in standby mode.. thank you.. Quote
markymark Posted November 21, 2007 Author Posted November 21, 2007 first i wanna thank you for this wonderful plugin which (almost) does everything i need my vfd for...my only question is wether you could add an option to display date/time in standby mode.. thank you.. Once I figure out how to do that ill do so Quote
Warp10 Posted November 21, 2007 Posted November 21, 2007 EDIT: Updated files (localization files where missing) -- NEW RELEASE 0.90 --- This new release adds - support for CU-U Charset VFDs (experimental, please check and report) - support for localization (english and german included) WBR MarkyMark Looks good! In "debug" mode, not all charactes of the charmap seem to display corrtectly, but the ones needed for the german Umlaute do! cheers, Thorsten Quote
markymark Posted November 21, 2007 Author Posted November 21, 2007 Looks good! In "debug" mode, not all charactes of the charmap seem to display corrtectly, but the ones needed for the german Umlaute do! cheers, Thorsten I only mapped the chars below 128 and umlauts so far. The CU-U charset does not support all high-ANSI chars anyway, e.g., a with one of the accents is missing. Quote
Warp10 Posted November 21, 2007 Posted November 21, 2007 I only mapped the chars below 128 and umlauts so far. The CU-U charset does not support all high-ANSI chars anyway, e.g., a with one of the accents is missing. That's what I've conceived :-) So thanks again for your work! cheers, Thorsten Quote
jascdvb Posted December 2, 2007 Posted December 2, 2007 Hallo, ich hab auch ein Grandia Gehäuse und bei mir gehts auch nicht. Liegt das Vielleicht an der Version der iMon Software? Welche könnte man mal testen?? Grüße Jan Quote
Lars_MQ Posted December 2, 2007 Posted December 2, 2007 @jascdvb Please in english. For german posts use the german thread! Quote
jascdvb Posted December 2, 2007 Posted December 2, 2007 @jascdvbPlease in english. For german posts use the german thread! Oops sorry, I didnt pay attention because there were other German threads I also have a Grandia case with the OEM iMon Display (USB). The plugin says it found an iMon but nothing is displayed regardless if the iMon software is started in plugin mode or not Maybe its the software version. Which software version would you recommend for a test and where to download? Regards Jan Quote
Salzhammer Posted January 3, 2008 Posted January 3, 2008 heyho guys today i got my Silverstone Grandia SST-GD01S-MXR Case with an Imon VFD and installed the Plugin but it says "Kein IMON VFD gefunden" anyone could help me to fix this issue? Quote
markymark Posted January 16, 2008 Author Posted January 16, 2008 heyho guys today i got my Silverstone Grandia SST-GD01S-MXR Case with an Imon VFD and installed the Plugin but it says "Kein IMON VFD gefunden" anyone could help me to fix this issue? see http://www.DVBViewer.info/forum/index.php?showtopic=23939 Quote
kapa Posted January 22, 2008 Posted January 22, 2008 EDIT: Updated files (localization files where missing) -- NEW RELEASE 0.90 --- This new release adds - support for CU-U Charset VFDs (experimental, please check and report) - support for localization (english and german included) WBR MarkyMark Hi, Thanks for a great app. Small typo in English.lng MSG_IMONFound="IMON VFD found should be: MSG_IMONFound="IMON VFD found" Quote
markymark Posted January 23, 2008 Author Posted January 23, 2008 Hi, Thanks for a great app. Small typo in English.lng MSG_IMONFound="IMON VFD found should be: MSG_IMONFound="IMON VFD found" Thx, ill fix that Quote
qb_jack Posted January 25, 2008 Posted January 25, 2008 Hello. Some user customizable texts would be great. An input field where we can set own text or strings from DVBV itself would make your little prog. much more powerful. Something like that: http://www.DVBViewer.info/forum/index.php?showtopic=22623 Any intentions to expand your prog. this way? Regards. QB_JACK Quote
markymark Posted February 4, 2008 Author Posted February 4, 2008 Hello. Some user customizable texts would be great. An input field where we can set own text or strings from DVBV itself would make your little prog. much more powerful. Something like that: http://www.DVBViewer.info/forum/index.php?showtopic=22623 Any intentions to expand your prog. this way? Regards. QB_JACK Indeed. However, that is about to come MUCH later Quote
kapa Posted March 26, 2008 Posted March 26, 2008 Hi, Here is lng file for Finnish users. Suomi.zip Kapa Quote
markymark Posted March 27, 2008 Author Posted March 27, 2008 Hi, Here is lng file for Finnish users. Suomi.zip Kapa Great! Nice work! I could include it in the next version if you could update the text to fit with version 0.96 (see german plugin thread for the download). Quote
radosch Posted April 10, 2008 Posted April 10, 2008 you should enable in iMon Manager that 3rd party applications use iMon. It's somewhere in the options. Then the iMon Manager software won't show anything on the vfd and the plugin can handle it completely. Hi, I have SilverStone LC16M case with iMON VFD. I downloaded the 0.96 version and then I checked the "3rd party" option in iMON Manager. There is a warning there saying that by checking this option iMON might not work properly Anyway, I started the IMONPlugin.exe and it confirmed that iMON VFD was found - so far so good. I have 2 problems however: 1. My VFD displays current date & time even if "3rd party" option in iMON Manager is checked (it displays it even after PC is shutdown!). As a consequence, the texts from DVBViewer are always overwritten by this date & time. Whenever I switch channel in DVBViewer I can see its name on the VFD for a fraction of a second (i.e. the IMONPlugin.exe seems to work just fine) - and then it is gone and I see the running date & time again Any ideas how to get rid of this date&time stuff? 2. By switching the "3rd party" option in iMON Manager my iMON remote control stopped working. Does this option swtich off the RC receiver as well? Is it possible to have both the RC and this plugin functional simultaneously? Or is it one or the other? Thanks for any help. Quote
ramonchin Posted May 2, 2008 Posted May 2, 2008 (edited) EDIT: Updated files (localization files where missing) -- NEW RELEASE 0.90 --- This new release adds - support for CU-U Charset VFDs (experimental, please check and report) - support for localization (english and german included) WBR MarkyMark I have Vista 32bits SP1 and this plugin works well until PC is suspended... When it resumes, VFD remains blocked showing only the Standby text...any DVBViewer information is showed. Help please. support_2_.zip Edited May 2, 2008 by ramonchin Quote
markymark Posted May 9, 2008 Author Posted May 9, 2008 I have Vista 32bits SP1 and this plugin works well until PC is suspended... When it resumes, VFD remains blocked showing only the Standby text...any DVBViewer information is showed. Help please. Please try the 0.97d version posted in the german thread. It should fix this issue, but MAY render the remote control useless. Just tell if it works Quote
ramonchin Posted May 11, 2008 Posted May 11, 2008 Please try the 0.97d version posted in the german thread. It should fix this issue, but MAY render the remote control useless. Just tell if it works Now it's working, thanks Quote
DolKbg Posted May 18, 2008 Posted May 18, 2008 Very nice plugin, I finally get usefull information in the LCD display of my HD160+, thanks a lot ! One small issue, the norwegian characters Øø (0x88 and 0x89 in the display character set table) are displayed as O and o on the display. Other norwegian characters such as Ææ and Åå looks ok. Displays ok in the Plugin Viewer. Regards DolKbg Quote
markymark Posted May 27, 2008 Author Posted May 27, 2008 Very nice plugin, I finally get usefull information in the LCD display of my HD160+, thanks a lot ! One small issue, the norwegian characters Øø (0x88 and 0x89 in the display character set table) are displayed as O and o on the display. Other norwegian characters such as Ææ and Åå looks ok. Displays ok in the Plugin Viewer. Regards DolKbg could you check if these characters are correct in your "Terminal" font? Quote
Max3D Posted June 8, 2008 Posted June 8, 2008 Thank you VM!! I'm using your plugin with Imon Ultra Bay...it works great! Just a question. Is it possible trought API programming to increase the LCD brightness? The contrast slide doesn't help. It's a good LCD but brightness is really awful. I can't read it from 2 meters. Quote
DolKbg Posted June 22, 2008 Posted June 22, 2008 could you check if these characters are correct in your "Terminal" font? Had some difficulties finding the Terminal font. Tried different applications but ended up with Notepad . And the answer is no, but that goes for all national specific characters, not only Øø. Thanks and regards DolKbg Quote
sosi Posted July 25, 2008 Posted July 25, 2008 Hi, Plugin work fine for me under Antec Black fusion LCD. Nice plugin. Regards... French.lng version 0.98 [TMainForm] MainForm_FontName="Tahoma" MainForm_FontSize=8 MainForm_FontCharset=1 TabGeneral_Caption="Général" TabLCD_Caption="iMON LCD" TabVFD_Caption="iMON VFD" TabStaticText_Caption="Affichage" TabDiskspaceMonitor_Caption="Moniteur d'espace disque" TabDisplayTest_Caption="Test" GBLanguage_Caption=" Language " GBOptions_Caption=" Options " CBClock_Caption="afficher l'heure avec le numéro de chaîne" CBChannelNumber_Caption="Affiché Le numéro de chaîne" GBEncoding_Caption=" Jeux de caractères VFD" CBEncoding_Items[0]="ANSI" CBEncoding_Items[1]="CU-U" GBLCDContrast_Caption=" Contraste " GBStandbyHibernate_Caption=" Veille et Veille Prolongée " GBShutdownText_Caption=" Arrêt " GBDiskspaceDisplayText_Caption=" Texte Affiché " GBScrolling_Caption=" Défilement " LbDiskHint1_Caption="%0:d = Capacité totale" LbDiskHint2_Caption="%1:d = Espace libre" GBDiskspaceFolder_Caption=" Dossier à surveiller " GBDiskspaceThreshold_Caption=" Seuil d'alerte " GBDisplayType_Caption=" Type d'afficheur (Nécessite un redémarrage) " CBDisplayType_Items[0]="iMON VFD" CBDisplayType_Items[1]="iMON LCD" LbWarnThresholdEnd_Caption="GB libre(s)" LbWarnThresholdStart_Caption="Avertir si inférieur à" LbStationName_Caption="Nom de la chaîne" LbTitle_Caption="Title" CBShowChars_Caption="Voir les caractères du code" BtnExpand_Caption="Paramêtres" BtnHide_Caption="Cacher" BtnQuit_Caption="Quitter" MSG_IMONFound="iMON VFD Détecté" MSG_IMONLCDFound="iMON LCD Détecté" MSG_IMONNotFound="iMON VFD or LCD non trouvé" CBScrollStation_Items[0]="Toujours" CBScrollStation_Items[1]="Une fois" CBScrollStation_Items[2]="Jamais" CBScrollTitle_Items[0]="Toujours" CBScrollTitle_Items[1]="Une fois" CBScrollTitle_Items[2]="Jamais" Quote
