buttonsNI. Posted January 8, 2010 Posted January 8, 2010 Use a fixed ip address.also try a different port 'rem same port in both apps Quote
packetstormer Posted January 8, 2010 Posted January 8, 2010 Not sure I understand your suggestion about fixed IP and different port. If I do a "net stat -an |find "2345" " I can see that the stream is listening on the correct port. Also, I have tried binding it to the local interface 0.0.0.0 and also loopback and it's assigned static IP address. It connects to the Transport Stream fine, as the log shows, so the source and destination ports are correct and communicating. Quote
dvbrewer Posted January 8, 2010 Posted January 8, 2010 Not sure I understand your suggestion about fixed IP and different port. If I do a "net stat -an |find "2345" " I can see that the stream is listening on the correct port. Also, I have tried binding it to the local interface 0.0.0.0 and also loopback and it's assigned static IP address. It connects to the Transport Stream fine, as the log shows, so the source and destination ports are correct and communicating. Did you try 127.0.0.1? Quote
packetstormer Posted January 9, 2010 Posted January 9, 2010 Did you try 127.0.0.1? Yep. That's what the loopback address is above. Quote
NikNak Posted January 9, 2010 Posted January 9, 2010 Had exactly the same problem as you packetstormer. I fixed it by going into hardware in DVBViewer and sellecting either (I say either because it was a while ago and im not able to get access to my settings right now) direct tuning, or open whole transponder. when one of those were ticked it made open epg to DVBViewer work again. Worth a go?... Quote
lotus Posted January 29, 2010 Posted January 29, 2010 Hi! this plugin seems to be exactly what I'm looking for, but I can't find any working link for download... Can anyone share it, please? thanks in advance, and thanks o djblu for coding it! Quote
dvbrewer Posted January 30, 2010 Posted January 30, 2010 Hi! this plugin seems to be exactly what I'm looking for, but I can't find any working link for download... Can anyone share it, please? thanks in advance, and thanks o djblu for coding it! I have it but you might want to contact the author DJBlu first. Quote
JoeH Posted May 22, 2010 Posted May 22, 2010 I would also like to download this program. If someone could post a link I would be grateful, or at least PM me. Thanks. Quote
dvbrewer Posted May 24, 2010 Posted May 24, 2010 I would also like to download this program. If someone could post a link I would be grateful, or at least PM me. Thanks. Uploaded to mediafire here. Quote
JoeH Posted May 27, 2010 Posted May 27, 2010 Thanks! BTW, it seems it is currently not working with Sky Italy, at least with the latest DVBViewer versions. Quote
dvbrewer Posted May 27, 2010 Posted May 27, 2010 Thanks! BTW, it seems it is currently not working with Sky Italy, at least with the latest DVBViewer versions. No it's only set up for UK, DJBlu's mediaportal plugin does Sky IT. Quote
dvbrewer Posted July 5, 2010 Posted July 5, 2010 Windows 7 update "Microsoft .NET Framework 4 Client Profile" seems to kill this plugin. Quote
buttonsNI. Posted July 13, 2010 Posted July 13, 2010 does djblu know this is a problem here? i see he is posting daily on the mediaportal site. maybe someone could let him know.. Quote
dvbrewer Posted July 13, 2010 Posted July 13, 2010 (edited) does djblu know this is a problem here? i see he is posting daily on the mediaportal site. maybe someone could let him know.. Unless you (or DVBViewer) want to pay him I'll doubt he'll do any more work on it as it is paid software. Also I was under the impression someone else is now working on the mediaportal version. Edited July 13, 2010 by dvbrewer Quote
buttonsNI. Posted July 13, 2010 Posted July 13, 2010 as far as i can see hes the main man over there ..as far as paid software is concerned.."open epg to DVBViewer" was never paid software. i think however that the most of his time is taken up with media portal and its quite possible that he isnt aware about the problem here... whether he gives a toss or not is another matter. Quote
dvbrewer Posted July 13, 2010 Posted July 13, 2010 as far as i can see hes the main man over there ..as far as paid software is concerned.."open epg to DVBViewer" was never paid software. I meant DVBViewer is paid for software, mediaportal isn't, there is a paypal link on the openepgtodvbviewer to reflect that (on mediaportal he only asks for donations to mediaportal, not personal). Quote
ErwinMeulman Posted August 29, 2010 Posted August 29, 2010 (edited) Edited August 29, 2010 by ErwinMeulman Quote
dvbrewer Posted September 5, 2010 Posted September 5, 2010 OK, there is a replacement for this using EPGCollector - instructions here, and XEPG- download latest beta here, discussion thread here, instructions to automate with recording service here . Quote
buttonsNI. Posted September 5, 2010 Posted September 5, 2010 maybe you could simplify the setting up of this instead of posting links to other disscussions from people who have their own problems with their set up. Quote
dvbrewer Posted September 24, 2010 Posted September 24, 2010 (edited) OK' date=' there is a replacement for this using EPGCollector - instructions here, and XEPG- download latest beta here, discussion thread here, instructions to automate with recording service here . maybe you could simplify the setting up of this instead of posting links to other disscussions from people who have their own problems with their set up. OK, here ya go download EPGCollector here download Xepg here download the two files linked at AVForums here Install Xepg to default location Install EPGCollector to a folder in My Documents i.e. C:\Users\Username\Documents\EPG Collector then, from BenRyder's post (in relation to the two AVforums files) rename the suffix to '.ini'. It is configured for the Sky BBC England / ITV South region. To get your correct region you need to change the 'Channels:4097,5' line to one that matches your region from the 'Region Mapping OpenTV GBR.txt' also attached. Just copy the ini file that into the main EPG Collector folder (make a backup of EPG Collector.ini) and replace/rename so it is called EPG Collector.ini You need to run it with a tuner command first so it gives you a list of your available tuners. I think the command is 'epgcollector.exe /tuner' then make a note of the number next to the available tuners. You cannot use DVBLink virtual tuners. So for example mine is the following: Code: Tuner:6,1 That means it will use Tuner 6 first, if that is busy will try tuner 1. Then run the program! It will create a tvguide.xml file which just needs copying to the location TV Source uses for EPG. You then setup the EPG within TV Source as normal. Run the program by opening a command line prompt by typing cmd in Windows start search box click cmd.exe Type CD C:\Users\Username\Documents\EPG Collector (replace that with your own EPGCollector folder location) Hit Return (First run the tuner command in BenRyder's post above- epgcollector.exe /tuner , then note the tuner numbers, exit and add the tuner numbers you want epgcollector to use in your EPGCollector.ini) Type epgcollector Hit Return, a TVGuide.xml should be created Open Xepg, click Add , add the location of your TVGuide.xml, EPGcollector.exe and the directory, click OK Locate your DVBViewer.exe when prompted by Xepg Click Channel Pairing, sort both sides Alphabetically (Alpha sort), pair manually or by name, click Apply when finished, Exit, then click Test Import to automate it with the recording service, follow essen's instructions in this post Edited September 24, 2010 by dvbrewer Quote
deggesim Posted October 1, 2010 Posted October 1, 2010 Where can I find a "Region Mapping OpenTV GBR.txt" file for other countries? I'm interested in the configuration for Sky Italia. Quote
buttonsNI. Posted October 1, 2010 Posted October 1, 2010 thanks dvbrewer .i got further this time than last .thanks for your effort but it seems my satix dual tuner dosnt work with epgcollector. Quote
dvbrewer Posted October 1, 2010 Posted October 1, 2010 Where can I find a "Region Mapping OpenTV GBR.txt" file for other countries? I'm interested in the configuration for Sky Italia. You might want to message user 'Toblerone', they mentioned they have it working with Sky IT here. thanks dvbrewer .i got further this time than last .thanks for your effort but it seems my satix dual tuner dosnt work with epgcollector. Try posting on the EPGCollector support forum on Sourceforge here, or look through the old support thread . Quote
deggesim Posted October 1, 2010 Posted October 1, 2010 You might want to message user 'Toblerone', they mentioned they have it working with Sky IT here. Thank you for the answer. I'll send a pm to Toblerone immediatly! Quote
daveyboyc Posted December 1, 2010 Posted December 1, 2010 Hi, Can anyone tell me why i have this error everytime i try to import the EPG from Xepg into the recording service? -- Fatal Error on line: -1, col: -1 Error evaluating the EndElement event! HttpSendRequest Failed. GetLastError = 12002 EXCEPTION MESSAGE---ERwSaxHandledAbort: --------------Statistics---------------------- Nodes crawled: 59242 Missing Channel IDs: 0 Missing Or Invalid Stop Times: 0 Missing Or Invalid Start Times: 0 Chunks Sent: 4 Paired <programme> items found: 5005 Depth 2 Nodes crawled: 345552 Depth 3 Nodes crawled: 11949 --------------Statistics---------------------- Error on importing EPG Error: Posting to Recording Service This happens everytime i click "Test Import" when the recording service is running. I've been playing around with it for a while now and it seems to import about half of the epg from the channels that i manually paired, but misses the other half.. Im using windows 7 with latest version for both RS and DVBViewer, correct credentials for RS in Xepg adn "delete old EPG" checked. Am i missing something? Quote
xtonys Posted December 19, 2010 Posted December 19, 2010 (edited) Done, there now is a FreeSAT EPG (PID 3842) entry in the MHW options. This should do it Hi I am new to DVBViewer and am very impressed with what it can do. I am in the UK and receive FTA channels from both Astra 28.2E and Turksat 2A/3A. I have figured out to get EPG data for Sky/Freesat channels with OpenEPG for now - but its a manual process. For Turksat, I cant find any active XML data to import, and DigiTurk wont release their EPG data as XML. I did find EPG data on one transponder which I can receive on the European beam. As you have done for Freesat, would it be possible for the next beta to include the following EPG data streams on Turksat? If this is possible, I can test these and see which one provides the missing EPG data I need for Turksat channels. Turksat 2A (42.0E) - 11804.00 V - Txp: 5 - Beam: Europe DVB-S (QPSK) - 24444 5/6 (37.5 Mbps) - NID:66 - TID:3 EPG DU Targeting112 SID 7010 PMT 7011 PCR 8191 EPG DU 2 (SD 306) SID 7020 PMT 7012 PCR 8191 EPG DU 4 (HD) SID 7040 PMT 7014 PCR 8191 EPG DU 5 PVR SID 7050 PMT 7015 PCR 8191 I hope this is possible. Thanks Tony Edited December 19, 2010 by xtonys Quote
dvbrewer Posted January 5, 2011 Posted January 5, 2011 (edited) I did find EPG data on one transponder which I can receive on the European beam. As you have done for Freesat, would it be possible for the next beta to include the following EPG data streams on Turksat? If this is possible, I can test these and see which one provides the missing EPG data I need for Turksat channels. Turksat 2A (42.0E) - 11804.00 V - Txp: 5 - Beam: Europe DVB-S (QPSK) - 24444 5/6 (37.5 Mbps) - NID:66 - TID:3 EPGCollector combined with XEPG may be able to do this, post on the discussion forum here. Edited January 5, 2011 by dvbrewer Quote
nzsjb Posted January 12, 2011 Posted January 12, 2011 EPGCollector combined with XEPG may be able to do this, post on the discussion forum here. EPG Collector will collect EIT data from that transponder. Around 126 stations, 7,000 entries. I have a transport stream dump of the tranponder which I have run through the Collector. Cheers Steve Quote
blackbooks Posted July 27, 2011 Posted July 27, 2011 (edited) Windows 7 update "Microsoft .NET Framework 4 Client Profile" seems to kill this plugin. I have tried using OpenEPGtoDVBViewer on Windows 7 but did not know this information. I installed .NET Framework 4 and the program would not load, as above. I then uninstalled .NET Framework 4 as I heard Windows 7 SP1 comes pre installed with .NET Framework 3.5 This does not work either. No loading at all,,, even with load as admin and run in XP mode. Running Win 7 sp1 64bit version, with updates applied after .net framework 4 was installed. i uninstalled .net 4, not the windows updates. Anyone have OpenEPGtoDVBViewer working on Win 7? Edited July 27, 2011 by blackbooks Quote
Lord Kram Posted August 13, 2011 Posted August 13, 2011 I have tried using OpenEPGtoDVBViewer on Windows 7 but did not know this information. I installed .NET Framework 4 and the program would not load, as above. I then uninstalled .NET Framework 4 as I heard Windows 7 SP1 comes pre installed with .NET Framework 3.5 This does not work either. No loading at all,,, even with load as admin and run in XP mode. Running Win 7 sp1 64bit version, with updates applied after .net framework 4 was installed. i uninstalled .net 4, not the windows updates. Anyone have OpenEPGtoDVBViewer working on Win 7? I too am having this problem, I actually did have this working a long time ago before I had to completely re-install everything when getting a new pc Is there not a similar alternative to openepg program? Ie something as easy to use and update the EPG for DVBViewer? Quote
Tjod Posted August 13, 2011 Posted August 13, 2011 FreeSat EPG is supported by the DVBViewer http://en.DVBViewer.tv/wiki/Options_EPG#Receive_FreeSat_EPG_Data. Quote
