Customized Programmliste: neutrinoCL Plugin
pmneo
[NeutrinoCL]
List0=902 <-- ID of Main-List, depends on your Skin
List1=999 <-- ID of Sub-List 1, depends on your Skin
Listx=yyy <-- ID of Sub-List x ( index must be continuously )
CurrentChannelList=953 <-- ID of that List, which will contain the CurrentChannelImage, for current active Channel (use -1 to disable this Feature )
CurrentChannelImage=current_channel.png <-- The image-path for CurrentChannelImage
BackgroundImage="background_neutrinoCLLogo.png" <-- The image-path for Background Image
SyncCurrentChannel=1 <-- 1 enable 0 disable
[blackList]
group0=exactGroupName <-- define excluding group here ( index must be continuously )
groupx=Free TV<-- define excluding group here ( index must be continuously )
channel0=exactChannelName <-- define excluding channel here  ( index must be continuously )
channelx=TV1 <-- define excluding channel here  ( index must be continuously )
[List]
ChannelNr_List=0 <-- List Index ( must be one of the defined )
ChannelNr_Column=-1 <-- List Column  (1-3 or -1 means disabled > do not show this entry )
ChannelNr_Order=0 <-- Ordering if you have configured more than one for this List and Column
ChannelNr_Head="" <-- Head-Text, if you have configured more than one for this List and Column
ChannelNr_Foot=" " <-- Foot-Text, if you have configured more than one for this List and Column
ChannelNr_StaticHead="" <-- Statid-Head-Text
ChannelNr_StaticFoot="." <-- Statid-Foot-Text
EPGInfo_MaxLength=50 <-- Any Longer Text will be trimmed
EPGEvent_MaxLength=0 <-- Currently not implemented
EPGInfo is the title of the show.
EPGEvent is the description of the show.
Greez pmneo
Hallo Zusammen!
Da ich inzwischen komplett auf eine Set-Top Box mit OpenPLI (enigma-2) umgestiegen bin, habe ich mal den Source-Code im ersten Post bereitgestellt.
Es würde mich freuen wenn das Plugin weiterentwickelt wird, leider fehlt mir die Zeit dazu!
MfG pmneo
  • 10 months later...
Ich bekomme dieses Plugin nicht zum Laufen. Eine Installationsanleitung konnte ich nicht finden. Daher habe ich die Inhalte der drei Ordner "Images", "OSDSkins" und "Plugins" in die gleichnamigen Ordner unter DVBViewerPro kopiert. Nach Neustart von DVBViewer finde ich aber weder im Menü "Plugins" noch im OSD-Menü (unter "Optionen") eine Spur von NeutrinoCL. Ich habe die neueste DVBViewer-Version sowie Win 8.1/64. Woran kann es liegen?
Im Menu plugins wirst du nichts finden. Schau mal im OSD Menu. Da ist ein Eintrag NeutrinoCL.
In OSDSkins ist nur etwas fuer die Concinnity skin. Wenn du eine andere Skin nutzt wirst du nicht viel sehen.
  • 1 month later...
Habe genau das gleiche Problem, alle Dateien kopiert und ersetzt (nutze den concinnity 3d skin) und kann im OSD Menu keinen Neutrino Eintrag finden.
Wenn ich im Skin Ordner die neutrinocl.xml in mychannels.xml umbenenne, öffnet sich zumindest die senderliste nur halt leer.
Jegliche Möglichkeiten mit zb: Favs=0 etc haben nichts bewirkt.
Hilfe;)
hi,
Ok Problem ist gelöst, denke wird auch Claus33 interessieren...
Mit Osd-Menü ist Nicht der Eintrag in den Optionen gemeint sondern ESC während Vollbild läuft...
Dann kommt "das OSD-Menu" und da ist der neutrino Eintrag vorhanden.
Darauf muss mann erstmal kommen:)
  • Like 1
  • 1 month later...
Es sieht gut aus, aber wie kann man das so einstellen, daß das Mausrad im OSD menü die links-rechts bewegung abbildet? unter den otionen bekomme ich das einfach nicht rein und ich möchte dafür nicht die tastatur nutzen müssen.
Hallo zusammen,
ich bin auf diesen Post gestoßen und finde die Umschaltmöglichkeiten sehr gut, da ich von einer Dreambox komme und man dort ebenfalls die Sender mit dem jeweils laufenden Programm sehen kann,
Doch leider stoße ich jetzt an eine Grenze.
Ich habe den BlueFuzz installiert und das neutrinoCL Plugin installiert.
Wenn ich in das OSD gehe, so sehe ich neutrinoCl und kann es auch auswählen.
Dann sehe ich das laufende Programm unten links in klein und auch das richtige Logo.
Aber es gibt keine Liste.
Ich vermute, das es ein Problem mit der neutrinoCL.ini gibt. Sie liegt bei mir im DVBViewer Ordner.
Ich weiß aber nicht was ich bei:
List0=902
List1=950
List2=951
List3=952
eintragen soll, bzw. woher ich die richtigen Nummer (IDs) bekomme.
Ich hoffe es kann mir jemand von euch weiter helfen.
mfg
Thomas
Viele Plugins funktionieren mit vielen Skins nicht ;-)
Weil sie nicht mehr gepflegt werden....
Ahh, das wäre in diesem Fall wirklich schade.
Wenn man eine Zeit lang mit dieser Umschaltmöglichkeit gelebt hat, fragt man sich oft, warum das bei anderen nich auch schon standard ist.
Es ist echt klasse, wenn man schon beim Umschalten schon bei 10? Sendern sehen kann was auf den einzelnen gerade läuft.
Wenn man das mal hatte, möchte man es nicht mehr missen. ;-)
Wie gesagt, es wird eingebunden, aber ich sehe keine Sender. Ich denke es liegt daran, daß ich bei den List Einträgen nicht weiss was ich dahin schreiben soll.
Ich hoffe es zumindest.
mfg
Thomas
Neutrino dll und die ini müssen ins Pluginverzeichniss.
Kannst ja auch mal TVman benutzen ist so was ähnliches nur etwas umfangreicher,ich glaube gibt da auch was fuer Bluefuzz.
Edited by BALOU
Das stimmt, Balou hat mich auf den richtigen Weg gebracht. Es lag nur noch an der ini-Datei, die mußte einfach ins Plugin-Verzeichnis gelegt werden und schon lief es.
TV-man schaue ich mir mal an.
Erst mal vielen Dank an Euch.
Thomas
Appropos pflegen. Wer mir TVman XML Skins inkl. PNG und passender CFG Datei schickt kann sicher sein das ich die im thread zum download anbiete.
Ich skine gelegentlich auf Anfrage. Da es aber Skins mit und ohne AutoEPG gibt spare ich mir den nicht unerheblichen Aufwand alles umzusetzen.
  • Like 1
  • 1 year later...
hallo wie installiere ich das? genau sowas habe ich gesucht. unglaublich gut.
  • 1 year later...
I can not handle installing this plugin in DVBViewer 6.0.3. Unpack the package in C: / programfilesx86 / DVBViewer but the menu looks unchanged.
  • 1 month later...
Hi All,
I have an issue with the EPG information reported by the Neutrino CL. I mean the current program at the right of each channel name. This info is correctly displayed for the DVB-T channels. But IPTV channels (that I have also in my channel list) does not have any EPG info reported by Neutrino. I would expect to see the EPG data there, because the DVBViewer EPG window correctly show EPG data for the IPTV channels also. So the issue is that Neutrino is not able to load this existing data. Any suggestion?
@hackbart I have successfully update this plugin. It is now able to correctly recognize and display IPTV channels previously imported by XEPG. (Thanks to @Delphi & @Griga, for their precious support). The new DLL file is 840KB, bigger than the maximum file size I can upload here. How can I share it?
Edited by leviscar
Hi, you can send me the zip file and i will upload it here.I did not found a way to increase your upload limit - invision changes the interface from time to time.
  • Thanks 1
I modified the source code provided by @pmneo, in order to add new useful features.
Changelog:
[17.12.2013]
- EPG data of IPTV channels (if previoulsy imported with xEPG) are now correcly displayed by NeutrinoCL.
- Channels logos are directly imported from the DVBViewer logos configuration file.
  In this way the plugin recognizes the logos associations defined using 'DVBViewer/Settings/Options/Channel Logos...'.
neutrinoCL.zip
  • Haha 1
