RS 1.30 not "playing" on changed PC: not web interface neither
cbrown1975
I tested RS on former PC: all was ok.
Now I've got all the problems in this topic title. To help me perhaps all following details can be useful (sorry for bad english):
Windows XP sp3, cabled LAN on 2 PCs (1 iMac, 1 winxp, this) router con DHCP not configurable.
into DVBViewer pro 5.3.1.0 options: RS connection failed, hardware: technisat Skystar S2 (flow settings?), but clear.
into Recording Service: webserver tested port 8089, 5050 (last surely opened on router), config.: server AV upnp [ ], Dvb server [√], RTSP [√], vlc (last version 2.1)
Installation on All User (mode=2)
Extract (errors found) from log debug:
01.11.14 21:02:47.687 TRecordingEngine loadsetup load vcr
01.11.14 21:02:47.687 TWebMain Init Rootfolder missing
01.11.14 21:02:48.812 TRecordingEngine StartService load setup
01.11.14 21:02:48.812 TRecordingEngine Recorderservice Enabled
01.11.14 21:07:48.265 TEPGUpdater AllocateHardware Open failed
Thanks
Your setup is not correct. If you use the RS you have to disable the hardware devices in the DVBViewer and replace it by virtual devices.
All gone OK after new complete setup/installation, but the error in RS installation (view picture).
No furthers problems, though.
