Settings for plugins in RS ?
How can access plugins options and settings in recording service in plugins1 folder?
You can try to edit the plugin config. files.
  • Like 1
The plugin structure is a pain in the neck. When using the RS (option checked) control of the other plugins shoud be possible at least from the local client. I guess it's simply forgotten to implement :rolleyes:
There is no easy way for a Service (or a plug-in ruing in the service user context) to interact with the current desktop user.
Mostly each plug-in would need support for whatever technique is used.
