draradic Posted March 28, 2020 Posted March 28, 2020 (edited) Hi, I have TV card Hauppauge WinTV (WinTV HVR-5500) in my PC. Have version 6.1.5.2 which runs at Windows 10 v1511 x86. After upgrade to new version signal drops down immediately to 60% at Status Bar. Also receiving of HD format not works. Al previous upgrades works perfectly. Any suggestions? Regards support.zip Edited April 7, 2020 by Griga Title corrected Quote
Griga Posted March 28, 2020 Posted March 28, 2020 AFAIK nothing has been changed in the handling of Hauppauge devices since 6.1.5.2. Can you verify that it is a 6.1.6.1 issue by returning to an older version? Previous installers are stored in C:\Program Files (x86)\DVBViewer\setup. Quote
draradic Posted April 6, 2020 Author Posted April 6, 2020 I take some time to delete all installation at my PC, and reinstall DVBViewer. Installation goes well, but when channel scan is started there is no detected signal for any channel. My provider is A1 and cable-TV. Tuner is recognized well. Problem is somewhere about detecting signal or parameters which described cable -TV. Database is empty because nothing is detected. I don't now what is may first install version but about ten upgrades all goings well without installation at glance. I am back to 6.1.5.2. Regards. Quote
vramor Posted April 16, 2020 Posted April 16, 2020 (edited) What about the scanning and analysing with TransEdit? Edited April 16, 2020 by vramor Quote
draradic Posted April 17, 2020 Author Posted April 17, 2020 I download Clean software and new driver form Hauppauge. After installation of new driver add latest version of DVBViewer everything works OK. So, it is necessary to install new driver for Hauppauge TV card. Regards Quote
