DVBHD 2080U cann't set DiSEqC1.1 or 1.2
zixi0007
DVBHD 2080U DiSEqC1.1 or 1.2 Setting is invalid.
Please to help me!
hardware.xml
<?xml version="1.0" encoding="UTF-8"?>
<settings>
<section name="@device:pnp:\\?\usb#vid_0572&pid_6830#20100502#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{972b7bb1-8149-4a72-b891-83e3c7dfe596}">
<entry name="HasCI">1</entry>
<entry name="UseHardwareFilter">1</entry>
<entry name="DVBS2">1</entry>
<entry name="NoStandard">1</entry>
<entry name="Name">DVB Digital TV</entry>
<entry name="TunerType">1</entry>
<entry name="Status">1</entry>
<entry name="InstID">DVB Digital TV 0</entry>
<entry name="DeviceNr">1</entry>
<entry name="Vendor">0</entry>
<entry name="Priority">2</entry>
<entry name="Tag">0</entry>
<entry name="ClassID">{EAFB3270-65C7-4662-99D6-C06D5E009FA3}</entry>
<entry name="Groups">255</entry>
<entry name="Retune">6</entry>
<entry name="SkipComponents">0</entry>
<entry name="DiSEqCCount">1</entry>
<entry name="Slot">0</entry>
<entry name="SlotFrequency">0</entry>
<entry name="UnicablePIN">0</entry>
</section>
DiSEqC.xml
<settings>
<section name="Commands2">
<entry name="1155">[E0 10 39 F0]</entry>
<entry name="1250">[E0 10 39 F1]</entry>
</section>
<section name="DiSEqC">
<entry name="Latitude">0</entry>
<entry name="Longitude">0</entry>
</section>
</settings>
but dvb dream is working well.
this is the dvbdream logs:
[04/21/13 10:26:22 : ] DeviceGetInterfaceInfo()...
[04/21/13 10:26:22 : ] Version: 03001300
[04/21/13 10:26:22 : ] >> DeviceGetList
[04/21/13 10:26:22 : 16] - Filter [DVB Digital TV]
[04/21/13 10:26:22 : 16] << DeviceGetList pDL->Count:1
[04/21/13 10:26:22 : 16] StartDevice() dwDeviceNo:0
[04/21/13 10:26:22 : 16] >> DeviceGetList
[04/21/13 10:26:22 : 47] - Filter [DVB Digital TV]
[04/21/13 10:26:22 : 47] << DeviceGetList pDL->Count:1
[04/21/13 10:26:22 : 391] BDA Device Name: [DVB Digital TV] (Tuner Type:1)
[04/21/13 10:26:22 : 391] BDA DevicePath: \\?\usb#vid_0572&pid_6830#20100502#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{972b7bb1-8149-4a72-b891-83e3c7dfe596}
[04/21/13 10:26:22 : 391] add_filter (DVB Digital TV)
[04/21/13 10:26:22 : 453] add_filter (Microsoft DVBS Network Provider)
[04/21/13 10:26:22 : 469] TuningSpace Name: 'Antenna' NetworkType: {00000000-0000-0000-0000-000000000000}
[04/21/13 10:26:22 : 469] TuningSpace Name: 'ATSC' NetworkType: {0DAD2FDD-5FD7-11D3-8F50-00C04F7971E2}
[04/21/13 10:26:22 : 485] TuningSpace Name: 'ATSCCable' NetworkType: {0DAD2FDD-5FD7-11D3-8F50-00C04F7971E2}
[04/21/13 10:26:22 : 485] TuningSpace Name: 'AuxIn1' NetworkType: {00000000-0000-0000-0000-000000000000}
[04/21/13 10:26:22 : 485] TuningSpace Name: 'Cable' NetworkType: {00000000-0000-0000-0000-000000000000}
[04/21/13 10:26:22 : 485] TuningSpace Name: 'ClearQAM' NetworkType: {143827AB-F77B-498D-81CA-5A007AEC28BF}
[04/21/13 10:26:22 : 485] TuningSpace Name: 'DD2 DVB-S' NetworkType: {FA4B375A-45B4-4D45-8440-263957B11623}
[04/21/13 10:26:22 : 485] Enumeration found 7 tuning spaces
[04/21/13 10:26:22 : 485] Found TuningSpace
[04/21/13 10:26:22 : 500] BDA Interfaces on Tuner Filter:
[04/21/13 10:26:22 : 500] GetTunerInterfaces: Pin types (2) :
[04/21/13 10:26:22 : 500] GetTunerInterfaces: Pin 0 Type = Input
[04/21/13 10:26:22 : 500] GetTunerInterfaces: Pin 1 Type = Output
[04/21/13 10:26:22 : 500] GetTunerInterfaces: Node types (2):
[04/21/13 10:26:22 : 500] GetTunerInterfaces: Node 0 Type = 0
[04/21/13 10:26:22 : 500] GetTunerInterfaces: Node 1 Type = 1
[04/21/13 10:26:22 : 500] GetTunerInterfaces: Node interfaces:
[04/21/13 10:26:22 : 500] GetTunerInterfaces: Interfaces on NodeType 0 (5 interfaces):
[04/21/13 10:26:22 : 516] GetTunerInterfaces: {992CF102-49F9-4719-A664-C4F23E2408F4} IID_IBDA_LNBInfo
[04/21/13 10:26:22 : 516] GetTunerInterfaces: {71985F47-1CA1-11D3-9CC8-00C04F7971E0} IID_IBDA_FrequencyFilter
[04/21/13 10:26:22 : 516] GetTunerInterfaces: {1347D106-CF3A-428A-A5CB-AC0D9A2A4338} IID_IBDA_SignalStatistics
[04/21/13 10:26:22 : 516] GetTunerInterfaces: {FAA8F3E5-31D4-4E41-88EF-D9EB716F6EC9} Unknown Interface - QueryInterface FAILED ! - hr = 0x80004002
[04/21/13 10:26:22 : 516] GetTunerInterfaces: {03CBDCB9-36DC-4072-AC42-2F94F4ECA05E} Unknown Interface - QueryInterface FAILED ! - hr = 0x80004002
[04/21/13 10:26:22 : 516] GetTunerInterfaces: Interfaces on NodeType 1 (3 interfaces):
[04/21/13 10:26:22 : 516] GetTunerInterfaces: {EF30F379-985B-4D10-B640-A79D5E04E1E0} IID_IBDA_DigitalDemodulator
[04/21/13 10:26:22 : 516] GetTunerInterfaces: {0FE4E87A-8E44-4E27-BE4A-4F03FC7D852B} Unknown Interface - QueryInterface FAILED ! - hr = 0x80004002
[04/21/13 10:26:22 : 532] add_filter (AVStream TS Capture)
[04/21/13 10:26:22 : 532] Capture Filter Name: AVStream TS Capture
[04/21/13 10:26:22 : 532] BDA Interfaces on Capture Filter:
[04/21/13 10:26:22 : 532] FAILED: cannot get the topology
[04/21/13 10:26:22 : 532] Warning: could not find IBDA_DiseqCommand interface on the topology
[04/21/13 10:26:22 : 532] Warning: could not find pBDADigitalDemodulator2 interface on the topology
[04/21/13 10:26:22 : 532] Getting property sets...
[04/21/13 10:26:22 : 532] Getting device type...
[04/21/13 10:26:22 : 532] fill_bda_info()...
[04/21/13 10:26:22 : 547] s_tunername_lowercase:dvb digital tv
[04/21/13 10:26:22 : 563] BDA extension detected: [amx.ext] (Found by matching tuner filter names)
[04/21/13 10:26:22 : 563] Setting property set functions...
[04/21/13 10:26:22 : 563] Loading BDA Extension : D:\Program Files\DVB Dream v2.1\Devices\bda_extensions\amx.ext
[04/21/13 10:26:22 : 563] fill_bda_info()...
[04/21/13 10:26:22 : 578] Getting BDA Options...
[04/21/13 10:26:22 : 578] add_filter (Sample Grabber)
[04/21/13 10:26:22 : 594] add_filter (MPEG-2 Demultiplexer)
[04/21/13 10:26:22 : 610] add_filter (BDA MPEG2 Transport Information Filter)
[04/21/13 10:26:22 : 610] Connecting ms mpeg-2 demultiplexer filter to transport information filter
[04/21/13 10:26:22 : 750] StartDevice() OK
[04/21/13 10:26:22 : 750] ----------------------------------------------------------------------------
[04/21/13 10:26:23 : 1891] SendDiseqc() E0 10 39 F1 Len:4
[04/21/13 10:26:23 : 1891] Trying OEM diseqc method...
[04/21/13 10:26:25 : 3532] FAILED: property_set_send_diseqc()
[04/21/13 10:26:25 : 3532] OEM diseqc method: FAILED
[04/21/13 10:26:25 : 3532] Trying standard SIMPLE PORT diseqc method...
[04/21/13 10:26:25 : 3750] SendDiseqc() E0 10 38 F3 Len:4
[04/21/13 10:26:25 : 3750] Trying OEM diseqc method...
[04/21/13 10:26:28 : 5969] FAILED: property_set_send_diseqc()
[04/21/13 10:26:28 : 5969] OEM diseqc method: FAILED
[04/21/13 10:26:28 : 5969] Trying standard SIMPLE PORT diseqc method...
[04/21/13 10:26:29 : 7453]
[04/21/13 10:26:29 : 7453] SetTuner() 4040000, H, 30600000 Mod:0 LOF:5150000 22Khz:0
[04/21/13 10:26:29 : 7672] waiting after tune request for signal... (tune_cmd_duration:219 ms total_wait:5781 ms)
[04/21/13 10:26:30 : 8125] Status: Locked in 672 ms bSignalLocked:1 bSignalPresent:1 lStrength:33 lQuality:100 nw:2
[04/21/13 10:40:28 : 846641] StopDevice()
[04/21/13 10:40:28 : 846719] BDACleanUp() completed.
Edited by zixi0007
DVBHD 2080U DVB-S2
driver information
; Copyright and Disclaimer:
; Bestunar Inc.
; All rights reserved.
[Version]
signature="$CHICAGO$"
Class=Media
ClassGUID={4d36e96c-e325-11ce-bfc1-08002be10318}
Provider=%Company%
DriverPackageType=PlugAndPlay
DriverPackageDisplayName=%PackageName%
DriverVer=04/03/2010,1.31.0403.0
CatalogFile=BtDtv.cat
[Manufacturer]
%Company%=MyCompany,NTamd64
[sourceDisksNames]
1=%DriverDisk%,,,""
[sourceDisksFiles]
BtDtv.sys=1
[MyCompany.NTamd64]
%BS6830.DeviceDesc% = BS6830, USB\VID_0572&PID_6830
[MyCompany]
[bS6830.NT]
Include= ks.inf, kscaptur.inf,ksfilter.inf, wdmaudio.inf, bda.inf
Needs= KS.Registration, KSCAPTUR.Registration.NT,MSPCLOCK.Installation, WDMAUDIO.Registration, BDA.Registration, bda.Installation.NT
AddReg= LwireDev.AddReg,BS6830.AddReg,NullTuner.AddReg,LWTS.AddReg
CopyFiles= CXLWIRE.CopyDrivers
[DestinationDirs]
CXLWIRE.CopyDrivers=10,system32\drivers
[CXLWIRE.CopyDrivers]
BtDtv.sys
[LwireDev.AddReg]
HKR,,DevLoader,,*ntkern
HKR,,NTMPDriver,,BtDtv.sys
HKR,,OkToHibernate,3,01
; Disable driver page out
HKR,,PageOutWhenUnopened,3,0
;HKR,,PageOutWhenUnopened,3,01
HKR,,DontSuspendIfStreamsAreRunning,3,01
[NullTuner.AddReg]
;---Tuner registry values------
HKR,"DriverData","TunerType",0x00010001, 0x00, 0x00, 0x00, 0x00
HKR,"DriverData","TunerI2CAddress",0x00010001, 0xC2, 0x00, 0x00, 0x00
HKR,"DriverData","Tuner2IFAddress",0x00010001, 0x86, 0x00, 0x00, 0x00
[LWTS.AddReg]
HKLM,System\CurrentControlSet\Control\MediaCategories\%TSPinID%,Display,1, 00,00,00,00
HKLM,System\CurrentControlSet\Control\MediaCategories\%TSPinID%,Name,,%TSPinName%
; TS filter parameters
HKR,"DriverData","dwTS_GEN_CNTRL",0x00010001, 0x04,0x00,0x00,0x00
HKR,"DriverData","dwIsTSStream",0x00010001, 0x00,0x00,0x00,0x00
HKR,"DriverData","dwTP_PACKET_SIZE",0x00010001, 0xBC,0x00,0x00,0x00
[bS6830.AddReg]
HKR,"DriverData","BoardType",0x00010001, 0x04, 0x00, 0x00, 0x00
HKR,"DriverData","TunerModel",0x00010001, 0x19,0x00,0x00,0x00
HKR,"DriverData","UseFreqOffsetDVBT",0x00010001, 0x7D, 0x00, 0x00, 0x00
HKR,"DriverData","DemodType",0x00010001, 0x02, 0x00, 0x00, 0x00
HKR,"DriverData","SoftFilter",0x00010001, 0x00, 0x00, 0x00, 0x00
HKR,"DriverData","RefClk",0x00010001, 0x01, 0x00, 0x00, 0x00
; Interfaces installation
[bS6830.NT.Interfaces]
AddInterface =%KSCATEGORY_BDATUNER%,%KSSTRING_BdaLWireSWTunerFilter%,CXBDATUNE_Interface,
AddInterface={FD0A5AF4-B41D-11d2-9C95-00C04F7971E0},%KsTSNameFilter%,TS_Interface
[CXBDATUNE_Interface]
AddReg = CXBDATUNE_Interface.AddReg
[CXBDATUNE_Interface.AddReg]
HKR,,CLSID,,%Proxy.CLSID%
HKR,,FriendlyName,,%BdaTunerFriendlyName%
[TS_Interface]
AddReg=TS_Interface.AddReg
[TS_Interface.AddReg]
HKR,,CLSID,,%Proxy.CLSID% ; {17CCA71B-ECD7-11D0-B908-00A0C9223196}
HKR,,FriendlyName,,%TSFriendlyName%
; Services installation
[bS6830.NT.Services]
AddService = BtDtv_SRV,2,LwireDevice.ServiceInstall
[LwireDevice.ServiceInstall]
DisplayName = %BTService.DeviceDesc%
ServiceType = 1
StartType = 3
ErrorControl = 1
ServiceBinary = %10%\system32\drivers\BtDtv.sys
; S t r i n g s
[strings]
Company = "Bestunar"
PackageName = "BtDtv Drivers"
DriverDisk = "BtDtv Drivers"
BTService.DeviceDesc = "BtDtv Driver"
BS6830.DeviceDesc = "DVBHD 2080U DVB-S2"
BdaTunerFriendlyName = "DVB Digital TV"
Proxy.CLSID = "{17CCA71B-ECD7-11D0-B908-00A0C9223196}"
ActiveMovieCategories = "CLSID\{da4e3da0-d07d-11d0-bd50-00a0c911ce86}\Instance"
MediaCategories = "SYSTEM\CurrentControlSet\Control\MediaCategories"
MediaSets = "System\CurrentControlSet\Control\MediaSets"
MediaInterfaces = "System\CurrentControlSet\Control\MediaInterfaces"
; Specify the GUID for the BDA Source Filters category in GraphEdit.
KSCATEGORY_BDATUNER="{71985F48-1CA1-11d3-9CC8-00C04F7971E0}"
KSSTRING_BdaLWireSWTunerFilter="{972B7BB1-8149-4a72-B891-83E3C7DFE596}"
BdaSWTuner.DeviceId = "{828B00F0-9A04-4692-8573-535B05DFF3F4}"
TSPinID = "{5237C937-0A21-4f7e-B338-DE0D0793D03F}"
TSPinName = "TS Out"
TSFriendlyName = "AVStream TS Capture"
KsTSNameFilter = "{452660BD-3B39-4e34-9B97-3D3BC054AF5D}"
Please to help me!
hardware.xml
<settings>
</section>
DiSEqC.xml
<settings>
</section>
</section>
</settings>
1) Close DVBViewer.
2) Open the file hardware.xml in the configuration folder with a text editor.
3) Change
to
<entry name="Vendor">32</entry>
4) Save, re-launch DVBViewer and try. Does it work?
If not you can also try the numbers 13, 15, 17, 18 and 27 in the same way. Good luck!
I set <entry name="Vendor">32</entry> and working well now.
thank you for your help!
Good to know. :) Looks like your device is compatible with DVBSky devices. We will add it in the DVBViewer hardware database, so that DVBViewer can detect it automatically. Until then better don't use the Options -> Hardware -> Scan Devices Button, because it will restore the old vendor value.
