LiMiT
Subtitles has changed in v6.0.4?
LiMiT
In v6.0.3 I was able to change/edit the display properties of the teletext subtitles (making the font larger, choosing font etc.). In v6.0.4 it seems that this is not possible any longer, or I haven't found a way to do this. Whatever I choose for font for the subs (ISDB, ATSC, SRT) it doesn't change on screen.
It seems it only gives me the default teletext font with default size.
Is there anyway to be able to change the font size etc. again in v6.0.4?
Share this post
Link to post
Griga
Such questions are (at least partly) answered by the Change Log -> see Program Files\DVBViewer\docs\changelog_en.html. Open it in your browser, go to the 6.0.4 section and look for keywords like teletext, subtitles, subtitle options... maybe you will discover some more interesting things.
Share this post
Link to post
LiMiT
Thank you for your reply, @Griga
I did read the readme, but missed the "Additionally the Subtitle Options have been generally reworked. They don't apply to teletext subtitles anymore (the corresponding settings are now completely covered by the Teletext Options).".
A sad day indeed as the possibility to change the teletext subs is great for smaller screens. I use DVBViewer in an old EEE PC (AIO) in my kitchen and used the teletext subtitle options to enlarge the font for better readability. I really hope that this will be brought back in a future version. I guess I'll have to revert back to v6.0.3.
Thank you for showing me the way, @Griga!
Edited by LiMiT
Share this post
Link to post
bccrew
Hello Griga,
The Teletext subtitles are now being displayed with a black box around them. My wife has difficulties reading the subtitles in 6.0.4 and the black bar is really annoying. Please bring back the functionality as in 6.0.3 where one could adjust the TT888 page subtitles font, size en shadings.
This is a rather dissappointing change, the first in many years I cannot support :(
As I'm not visually impaired but hearing impaired, I always loved the extra bit of control to change these settings.
Edited by bccrew
Share this post
Link to post
Griga
That's how the broadcaster wants them to be displayed.
Many broadcasters are using colours or the subtitle position to indicate who is speaking (quite important for the hearing impaired, as you will understand). Additionally the subtitles are now synchronized properly with video according to the broadcasted time stamps. This all didn't work with the previous method. That's why it has been changed.
Share this post
Link to post
bccrew
Hi Griga,
I understand the idea behind the colors etc. I was just wondering why the 2 possibilities cannot stand next to each other? Can the synchronisation not be combined with changing the font etc.
The black bar is just annoying, that was the reason for me to not use the setopbox of my ISP but choose for a software solution :)
Share this post
Link to post
bccrew
Griga,
Any way we can convince you or the devs to revert this partly? I really hope the option to change the TT subtitle font will be implemented again.
I do understand the sync issues but maybe they can be combined? It would keep me in line to update to the newest version.
Atm, it's holding me and LiMiT back to ugprade to 6.0.4
Thank in advance!
Share this post
Link to post
bccrew
In addition I just wanted to inform you that some of the channels in Belgium don't have support for color codes so it's just all white text with a black box surrounding it.
Share this post
Link to post
Griga
Thanks for feedback. I will have another look at it when development focuses again on DVBViewer. Currently the DVBViewer Media Server takes center.
  • Like 2
Share this post
Link to post
bccrew
Griga, sorry to ask another question here but did the MBit display of a stream also disappeared in the status bar?
I cannot find any changes regarding this in the Changes list of V6?
Did this get removed by accident when reworking the signal strength button?
Share this post
Link to post
Griga
Here it is still visible.
Please note that it is only available when the DVBViewer Filter (DVB Source) is used as source filter - see Settings -> Filters.
Share this post
Link to post
bccrew
Well, as a matter of fact I'm using DVBSource... I took the screenshot through RDP session so no audio state..
Edited by bccrew
Share this post
Link to post
Griga
Did you activate the support for visual impaired users on Options -> Extended?
Share this post
Link to post
bccrew
Yes, unckecking this JAWS brought the Mbit indication back ;)
There seems to be a small typo though?
(JAWS scripts omly) shouldn't it be only?
Edited by bccrew
Share this post
Link to post
Griga
Fixed, including the double acceleration key (visual for both checkboxes, so it doesn't work for the second).
Back to the original topic: I think teletext subs should have an adjustable background transparency.
That can be achieved easily. However, it didn't even work in previous versions due o a bug, as I've just found out. Options -> Subtitles only allowed to switch background display on and off. The slider didn't take effect.
I've also tried outline style, but that doesn't look really good with the teletext subtitle output.
Share this post
Link to post
Griga
P.S. Would you like to test the changes?
Share this post
Link to post
bccrew
Griga,
The background transparancy looks neat. Can 0% also be applied?
What about changing the font? Still possible?
Send me a pm with a beta build to test if you want.
Happy New Year btw!  :)
Share this post
Link to post
Griga
Happy new year! Check your PMs....
Share this post
Link to post
bccrew
Hi Griga,
I have compared both versions (6.0.3.0 versus 6.0.4.3 beta)
I tried to reconstruct the same settings I am used to as in 6.0.3.0 with a normal Arial font of size 30.
6.0.3.0
6.0.4.3 beta
While I respect that the creator of the TT subtitles places the subtitles wherever he/she want on the screen to avoid white text over a white/light background, the font seems to be rather squeezed horizontally. I have noticed this with every font I choose.
If you look at the screenshots, you can clearly see that the older "look" was better :) Don't you agree?
These are resized windows on my PC but imagine you view this on a +48" HDTV. The whitespace between all letters in 6.0.4.3 is doing something weird with my brain. It's harder to keep up with reading.
There's even a term specifying this: "Kerning"
https://wiki.openoffice.org/wiki/Documentation/FAQ/Writer/FormattingText/The_space_between_the_letters_in_a_word_seems_just_a_bit_too_wide._It_would_look_better_if_that_space_is_being_reduced._How_can_I_achieve_this%3F
https://www.coverdesignstudio.com/kerning-leading-spacing-book-covers/
Edited by bccrew
Share this post
Link to post
Griga
Mostly broadcasters use double heigth characters for teletext subtitles because normal height characters are too small. Since Windows does not provide characters with such a size DVBViewer creates them by stretching normal characters vertically.
DVBViewer 6.0.4 renders teletext subtitles in the same way as other teletext pages. Have a look at the teletext window or the OSD teletext for comparison. Please note that teletext is a very old system where each character occupies a fixed size box of a 40 columns x 24 rows grid, thus requiring a monospaced display. Double height characters occupy two vertically adjacent cells. Broadcasters rather should use the modern graphical DVB subtitles for better quality.
The previous way of rendering (up to 6.0.3) extracted the text from the teletext page and used the SRT subtitle output routine for always displaying the subtitles centered on the screen, thus disregarding the original size, position and colour. Additionally special characters from the teletext block graphics set were discarded, because they are not availabe in Windows fonts. A teletext renderer under Windows must be able to "paint" these characters without using a font.
  • Like 1
Share this post
Link to post
LiMiT
Thank you @Griga for visiting the subtitling again. Like @bccrew mentions, the ability to edit the fontsize of the subtitles is far more important to me than having the bleeding edge version.
If possible, could these two co-exist in DVBViewer, please? For me, the black background isn't an issue, but the size of the font...
Edited by LiMiT
  • Like 1
Share this post
Link to post
bccrew
I really was hoping that the new version of DVBViewer would integrate both methods of displaying TT888 fonts. The need for original TT colors was never really there. The spacing between the letters is just too disturbing. That's also the reason why I didn't like my original STB of my provider. No configuration options.. :(
About the special symbols I understand that the 'music note' symbol is probably one of the symbols not available in every Windows font.
Isn't there a way of extracting the colors of the TT subtitle stream and add them to the SRT routine?
I know that SRT files do support colors?
http://www.visualsubsync.org/help/srt
1
00:00:12,000 --> 00:00:15,123
This is the first subtitle
2
00:00:16,000 --> 00:00:18,000
Another subtitle demonstrating tags:
<b>bold</b>, <i>italic</i>, <u>underlined</u>
<font color="#ff0000">red text</font>
So again, a cry for adding the old method again.. :(   We all know TT will once cease to exist and most providers will eventually switch to DVB subtitles or an alternative method. So I don't see why DVBViewer can support both methods until the end..  There weren't any users complaining about this right?
I see some changes about SRT handling in the changelog of 6.1.0.0 so the SRT routine is definitely still there? :)
@Griga @hackbart @LiMiT
Edited by bccrew
Share this post
Link to post
bccrew
No answer? :(
Share this post
Link to post
Griga
I don't know when I will find time for this topic again. There are a lot of other important things to do.
Share this post
Link to post
bccrew
@Griga Is this still on the todo list for one of the next DVBViewer releases? What do you think?
Share this post
Link to post
bccrew
@Griga Is this something that can be returned as a feature? I'm still on version 6.0.3.0  and if you look at the screenshots I posted here, you can understand it still looks awful to read Teletext subtitles for us with the newer versions.
Share this post
Link to post
bccrew
@hackbart @Griga  Too bad this is still a problem for us at home. Will you consider this again in one of the next versions please?
Thanks
Share this post
Link to post
bccrew
Too bad you guys don't reply :(   It's not hard to just say yes or no..
Share this post
Link to post
blomman
the new subtitle layout is impossible to read for me, wish the old layout was available again...
Share this post
Link to post
Griga
I've found some time to look into this matter again.
Returning to the old teletext subtitle state is not possible, because there are too many disadvantages, as already mentioned here and here. However, I've managed to implement a new (optional) way of rendering teletext subtitles, that keeps the intended subtitle size, position and colour, though it uses variable spacing. There is only one drawback left: The special teletext block-graphic characters can not be displayed in this way.
Basically the rendering is controlled by a new subtitle option called "Use teletext font for  teletext, ATSC and ISDB subtitles". If switched off (default), the font settings from the subtitle options page with variable-pitch rendering are used for teletext subtitles, otherwise the font settings from the teletext options with fixed-pitch rendering and teletext block-graphic characters. So everybody can select what fits his needs best.
Please let me know if you want to test it. That's how it looks like (with Tahoma font, semi-transparent background and a bit of character outlining):
  • Like 1
Share this post
Link to post
bccrew
Hi @Griga
You are my hero! Please send me test link.
Share this post
Link to post
Griga
vor 12 Stunden schrieb bccrew:
You are my hero!
That's how one can easily become a hero: Just remove something that people will be missing. Then after some time add it again :) Anyway, check your PMs...
In the meantime I've found another drawback of the variable-pitch rendering. The positioning is done by first calculating the area that would be occupied by fixed-pitch rendering (as intended by the broadcaster) and then centering the shorter variable-pitched text horizontally and vertically within this area. By this, text that is supposed to be centered on the screen remains centered.
Unfortunately there are channels (particularly BBC) that sometimes broadcast a kind of live teletype subtitles. That means, the text is typed while someone is speaking, and each new letter is broadcasted immediately. Thus the teletext subtitles don't appear as whole lines at once, but letter by letter in lines that get longer and longer. Since the lines rendered with the method described above are not left aligned, but always centered in a given area, the letters continuously change their position, making it very hard to read the text.
I have no solution for it up to now. BBC viewers can switch over to DVB subtitles, but what if there are only teletext subtitles? Returning to the fixed-pitch rendering is the only possibility to avoid this issue.
Share this post
Link to post
bccrew
Hi @Griga,
Luckily, the BCC issue is not the case at the moment for my broadcaster. It looks very nice now. I also think it's a very rare case scenario?
When watching for example Tour De France or matches by the belgian Football team Red Devils, subtitles are broadcasted with a delay of about 10-20 seconds because that's the time the typist needs to enter the correct words. But they are broadcasted as whole sentences in TT888 and most of the times, the sentences are small summaries of what has been said before.
Edited by bccrew
Share this post
Link to post
bccrew
This is an example of the new version with livetype subtitles during the Yorkshire 2019 World Championships elite men’s individual time trial. I added a bit of outline to the subtitles but as you can see our broadcaster VRT places the subtitles on top of the screen because of the many informational textblocks that are shown on the bottom of the screen.
Edited by bccrew
Share this post
Link to post
  • Similar Content
    • NeMiLose
      By NeMiLose
      I have USB device Hauppauge WinTV-soloHD and I use it for DVB-C.
      I have been using DVBViewer Pro with the Recording service to watch some channels on a remote location, and it works perfectly.
      Recently, I wanted to record a movie on some other channel and then I realized that the subtitles are not recorded. In fact, subtitles are not detected in DVBViewer (Subtitles menu option is grayed-out in the right-click menu), but in the recorded TS video MPC-HC shows all available subtitles (11 of them), but none of them are working. DVBViewer is also not showing EPG for this channel. Something else I have noticed. It is not important for me, but maybe it is important for the problem. There are main audio language and two more languages. DVBViewer correctly shows them in the menu, but only main audio reproduces sound. All of these issues are not present when I watch that channel on LG TV. It shows all subtitles, EPG works and all three audio languages are working.
      On some other channel, I was able to see subtitles in DVBViewer and also in the recording.
      Here is an example of recorded not-working channel: https://we.tl/t-mSq0GiZosD
      Here is an example of recorded working channel: https://we.tl/t-VacaTglL1W
      I have also attached support.zip.
    • wikings1
      By wikings1
      Hello i have a problem whit Dvb subtitles. They are out of sync.
      You can test this channel C More Series HD (swe)  on thor 0.8 w
      Is there any fix for this?
    • G0ldTeam
      By G0ldTeam
      How to extract subtitles from registration
