hbbtv - Plug-in missing
hi,
i cant see any content on hbbtv submenu and i see "Plug-in missing"
what is missing? i installes hbbtv engine and channel have red symbole
Thanks, it is the application/oipfSearchManager which is not set to invisible. So the html renderer shows a missing plugin message. I fixed this. In the next version you won't see the error message anymore. Besides that the application (http://www.replaytvmhp.rai.it/hbbtv/launcher/RemoteControl/index.html?delivery=0) does not do anything. Which needs a few more tests from my side.
Uncaught SyntaxError: Unexpected end of input
script20180702_032805PM.js:302Uncaught TypeError: Object http: has no method 'startsWith'
about:blank:1Uncaught SyntaxError: Unexpected end of input
releaseinfo
"HBBTV TCMD 872"
asciiArt
"                  __---__                         ______
                 /    ___\_             o  O  O _(      )_
                /====(_____\___---_  o        _(    RAI    )_
               |                    \        (_  AI-YAI!!!   )
               |                     |@        (_  Shot      _)
                \       ___         /           (__  Again!__)
   \ __----____--_\____(____\_____/                (______)
  ==|__----____--______|
   /              /    \____/)_
                /        ______)
              |           _|  |
         ______\______________|______
       /_____________*____*___________\
      /________________________________\
     /__________________________________\
          |________________________|
          |________________________|"
This is what the debugger says ?
  • Thanks 1
Okay, the https page of the application needs a valid certificate. I made a work around and open the main page instead of the loader.  You should now be able to open the hbbtv services. I did not checked their content, but it loads at least. I assume the videos won't play properly, caused by their proprietary DRM.
  • Like 1
thank you,
i cant see content of hbbtv sofar , i dont know why! , maybe its country restriction
im in iran now
The hbbtv.xml file will be downloaded from our server and this one contains all the information required for the hbbtv browser.
