OS: Windows 10, 64bit.
Tuner: TBS 5980.
Sattelite: 4.9 Astra and 36.0 Eutelsat (connected via DiseqC).
Software: Recording Service + Kodi.
Problem: sometimes on channel switch Recording Service hangs up.
Last part of log file (svcdebug.log):
27.05.16 11:42:10.904 TBDACITBSModule CI Base SetTuner Entering
27.05.16 11:42:10.904 TBDACITBSModule CI Base SetTuner Leaving
27.05.16 11:42:11.034 TBDACITBSModule WndProc Received PMT ready
27.05.16 11:42:13.173 TUPnPAnnounce InitWsocket 192.168.1.120
27.05.16 11:42:42.740 TRecordingEngine Resume Reset Timer signaled
27.05.16 11:42:42.740 Reset Start
27.05.16 13:14:12.028 TRecordingEngine Standby PBT_APMSUSPEND
27.05.16 13:14:12.029 TUPnPAnnounce Stopped
27.05.16 13:14:12.029 TRTSPWebserver Disconnected
27.05.16 13:14:12.037 Release TBS 5980 CI Tuner
27.05.16 13:14:12.037 Destroy TBS 5980 CI Tuner
27.05.16 13:14:13.043 Destroyed TBS 5980 CI Tuner
27.05.16 13:14:13.044 hamDeleted TBS 5980 CI Tuner
27.05.16 13:14:13.049 TSrvDataModule Freed
27.05.16 17:35:32.504 TRecordingEngine Time changed
27.05.16 17:35:32.737 TRecordingEngine Resume PBT_APMRESUMESUSPEND
27.05.16 17:35:32.737 TRecordingEngine Resume Processing...
27.05.16 17:35:32.737 TRecordingEngine Sleeping -1
27.05.16 17:35:32.737 ReleaseStandbyblock PBT_APMRESUMESUSPEND
27.05.16 17:35:32.740 TRecordingEngine FWakeUp do
27.05.16 17:35:32.740 TRecordingEngine NextEPGUpdate 5/28/2016 12:47:19 AM
27.05.16 17:35:32.740 TUPnPAnnounce Start
27.05.16 17:35:32.741 TUPnPAnnounce InitWsocket 127.0.0.1
27.05.16 17:35:32.758 TRecordingEngine Resume PBT_APMRESUMEAUTOMATIC
27.05.16 17:35:32.758 TRecordingEngine Resume Processing...
27.05.16 17:35:32.758 TRecordingEngine Sleeping 0
27.05.16 17:35:41.597 TBDA_TBS Opendevice bvTurbosight
27.05.16 17:35:41.597 TStreamClient AllocateHardware TBS 5980 CI Tuner
27.05.16 17:35:41.597 TBDA_TBS SetTuner TType: 1, Freq: 11996, Symrate: 27500, LOF: 10750, Tone: 0, Pol: 0, DiseqC: 3, FEC: 3, APID: 305, VPID: 205, PMT: 1905, SID: 19105, TID: 19, NID: 112, SatMod: 6, DiseqCVal: 0, Flags: 25
27.05.16 17:35:42.309 TBDACITBSModule CI Base SetTuner Entering
27.05.16 17:35:42.309 TBDACITBSModule CI Base SetTuner Leaving
27.05.16 17:35:42.507 TBDACITBSModule WndProc Received PMT ready
27.05.16 17:35:43.388 TUPnPAnnounce InitWsocket 192.168.1.120
27.05.16 17:36:12.734 TRecordingEngine Resume Reset Timer signaled
27.05.16 17:36:12.734 Reset Start
27.05.16 17:36:13.140 TStreamClient AllocateHardware TBS 5980 CI Tuner
27.05.16 17:36:13.141 TBDACITBSModule CI Base SetTuner Entering
27.05.16 17:36:13.141 TBDACITBSModule CI Base SetTuner Leaving
27.05.16 17:36:13.389 TBDACITBSModule WndProc Received PMT ready
27.05.16 18:02:08.126 TBaseProcess API_HandleStatus
27.05.16 18:21:23.271 TStreamClient AllocateHardware TBS 5980 CI Tuner
27.05.16 18:21:23.272 TBDA_TBS SetTuner TType: 1, Freq: 12265, Symrate: 27500, LOF: 10750, Tone: 0, Pol: 0, DiseqC: 3, FEC: 3, APID: 403, VPID: 323, PMT: 2903, SID: 31003, TID: 10, NID: 112, SatMod: 1, DiseqCVal: 0, Flags: 25
27.05.16 18:21:23.595 TBDACITBSModule CI Base SetTuner Entering
27.05.16 18:21:23.595 TBDACITBSModule CI Base SetTuner Leaving
27.05.16 18:21:24.023 TBDACITBSModule WndProc Received PMT ready
27.05.16 19:22:15.126 Release TBS 5980 CI Tuner
27.05.16 19:22:15.127 Destroy TBS 5980 CI Tuner
27.05.16 19:22:16.154 Destroyed TBS 5980 CI Tuner
27.05.16 19:22:16.154 hamDeleted TBS 5980 CI Tuner
27.05.16 20:37:02.852 TBDA_TBS Opendevice bvTurbosight
27.05.16 20:37:02.852 TStreamClient AllocateHardware TBS 5980 CI Tuner
27.05.16 20:37:02.853 TBDA_TBS SetTuner TType: 1, Freq: 12265, Symrate: 27500, LOF: 10750, Tone: 0, Pol: 0, DiseqC: 3, FEC: 3, APID: 403, VPID: 323, PMT: 2903, SID: 31003, TID: 10, NID: 112, SatMod: 1, DiseqCVal: 0, Flags: 25
27.05.16 20:37:03.460 TBDACITBSModule CI Base SetTuner Entering
27.05.16 20:37:03.460 TBDACITBSModule CI Base SetTuner Leaving
27.05.16 20:37:03.717 TBDACITBSModule WndProc Received PMT ready
27.05.16 20:46:11.125 TStreamClient AllocateHardware TBS 5980 CI Tuner
27.05.16 20:46:11.126 TBDA_TBS SetTuner TType: 1, Freq: 11843, Symrate: 27500, LOF: 10600, Tone: 1, Pol: 0, DiseqC: 4, FEC: 3, APID: 6252, VPID: 6251, PMT: 6250, SID: 6250, TID: 13, NID: 85, SatMod: 1, DiseqCVal: 0, Flags: 25
27.05.16 20:46:11.768 TBDACITBSModule CI Base SetTuner Entering
27.05.16 20:46:11.768 TBDACITBSModule CI Base SetTuner Leaving
27.05.16 20:46:11.912 TBDACITBSModule WndProc Received PMT ready
Neither Kodi, nor DVBViewer after this problem occurs, could not tune and show any TV channel. DVBViewer shows following error:
Recording Service status hangs at "Stopping" state.
The only way I can get TV back to work is to restart the PC or to restart service using command line:
sc queryex DVBVRecorder
taskkill /f /pid 1860
net start DVBVRecorder
What could cause this sort of problem? Defective TBS driver? Recording Service bug?
Edited by vxl
Thank you for suggestion.
I will give this DLL a try.
What CI-module are you using?
  • 8 months later...
I have a similar problem with Recording Service. I was playing a game earlier and when I got in Kodi it showed that it couldn't connect to DVBViewer server. Then I checked in task manager->services and DVBRecorder shows as "Stopping". Can't do anything but restart or kill the service and restart it as vxl mentioned.
I'm using a generic chinese tuner. Looks like this:
Digital-satellite-DVB-t2-usb-tv-stick-Tu
This is not a TBS card and there is no CI involved. How could it be a similar problem??
Is the actual result, Recording Service getting stuck, as I said in the previous post. I either have to restart my PC or kill the service using Command Prompt and start it again. This was the only thread I've found specifying the same problem I have.
Edited by Hop Tzop
