Nikola Vranic Posted December 14, 2017 Posted December 14, 2017 Hello, I manage to create manual channel list from TS files and to add EPG data from SI stream. Everything works fine and well displayed in EPG windows. But, for my analyses I need to export all EPG data and to get EPG event ID beside title, short/long description ... in xml. Can somebody please help me with this? Quote
sir drake Posted December 14, 2017 Posted December 14, 2017 Hi Nikola, There is a way of how to get the wanted data. it is unkown to me how you grab the data you get now from TS-file. but if you have the DMS-Server too, you can give a try to Recording Service (DMS) web API http://en.DVBViewer.tv/wiki/Recording_Service_web_API#.2Fapi.2Fgetfavourites.html there you will find "hopefully" your answer. you can manage the requests as you need them by channel by .......some examples to be used by a web-browser like Firefox by channel ( shpuld be extracted from result by requesting all data. see next example below ) http://localhost:8089/api/epg.html?lvl=2&channel=<CHANNEL_ID> all ( huge list of response )http://localhost:8089/api/epg.html?lvl=2 rgds Quote
