TransEdit: force TCP AVP for SAT>IP sources
userip
Using the TransEdit, some times I use software SAT>IP servers for testing. Some of these servers, like the Recording Service, support the TCP streaming (aka RTSP AVP Interlaved). And inside the "TransEdit.ini" file I see the entry "UseTCP.X" for each tuner. However, it only works with RS sources.
Please, can you expand this support for any SAT>IP server? I know, not all support it, but if they support it, then will be very useful.
Thank you!
Link to comment
  • 4 weeks later...
  • 4 months later...
Why this not enabled? The current code supports TCP transport. And other SAT>IP servers also does. So, why not enable it?
Thank you!
Link to comment
