oleq Posted September 19, 2020 Posted September 19, 2020 (edited) When I play this stream: https://www91.zippyshare.com/v/HpXZhE2M/file.html and try to run Teletext/Subtitle Analyzer on PID 8125 (Teletext subtitles for channel WP) - TransEdit will freeze, need to kill it. I think this is something new, started to happen on 4.2.4, might be related to this fix, but not sure... Edited September 19, 2020 by oleq Quote
Griga Posted September 20, 2020 Posted September 20, 2020 Your link yields a "403 Forbidden" error message. Quote
oleq Posted September 20, 2020 Author Posted September 20, 2020 Weird, works for me, but reuploaded to better server - sorry for that. New link: https://sklep.you2.pl/191.7z Quote
Griga Posted September 20, 2020 Posted September 20, 2020 That link works, and I could spot the problem. A classical (unhandled) buffer overflow. It's a general teletext parser issue and may occur with all kinds of teletext, not only with your sample. Thanks for the report and the sample. Please check your PMs. Quote
oleq Posted September 20, 2020 Author Posted September 20, 2020 Thanks - checked test version, verified about 15 different teletext services for different channels - now everything OK Thanks for very fast reaction and fix Quote
