Hauppauge WinTV-soloHD - only some channels found
Similar Content
By NeMiLose
I have USB device Hauppauge WinTV-soloHD and I use it for DVB-C.
I have been using DVBViewer Pro with the Recording service to watch some channels on a remote location, and it works perfectly.
Recently, I wanted to record a movie on some other channel and then I realized that the subtitles are not recorded. In fact, subtitles are not detected in DVBViewer (Subtitles menu option is grayed-out in the right-click menu), but in the recorded TS video MPC-HC shows all available subtitles (11 of them), but none of them are working. DVBViewer is also not showing EPG for this channel. Something else I have noticed. It is not important for me, but maybe it is important for the problem. There are main audio language and two more languages. DVBViewer correctly shows them in the menu, but only main audio reproduces sound. All of these issues are not present when I watch that channel on LG TV. It shows all subtitles, EPG works and all three audio languages are working.
On some other channel, I was able to see subtitles in DVBViewer and also in the recording.
Here is an example of recorded not-working channel: https://we.tl/t-mSq0GiZosD
Here is an example of recorded working channel: https://we.tl/t-VacaTglL1W
I have also attached support.zip.
By Tomas Peceny
I am an old user of the DVBViewer; the DVBViewer always prevented switching off the PC or hibernate it. I wish to start recordings from a hibernated PC.
I have tried to find information in this forum and only found that no action is needed. The computer does not go into sleep mode when DVBViewer is running; when I turn DVBViewer off, the computer does not wake up in the set time. What is the correct procedure?
By DetlefM
Hat jemand erfolgreich einen DVB-S2 USB Stick oder entsprechende Box mit Windows 10 / Mediaserver am Laufen?
Gibt es eine Liste: Empfohlene Hardware?
Will meinen Aufnahme Windows 10 PC mit einer neuen Schüssel verbinden-.
By Tomas Peceny
I have two identical PCs Dell Optiplex 7010 with Windows 10 and Evolveo T2 USB tuners. One of them plays well the new T2 HD television sending and the *.ts records via the DVBViewer Pro 6.0.3.0 and LAV 0.74.1-x64 , while the other one plays badly via the DVBViewer Pro 6.1.5.0 and the same LAV 0.74.1-x64. I'd like to try the older DVBViewer Pro 6.0.3.0 with the other PC. How can I download it? (Now, I solve DVBViewer troubles with updating Windows 10 by enabling the Windows update manually and then reinstalling the Evolveo driver or LAV if necessary.) Thanks!
By berek
ich teste gerade die TPM und SecureBoot von Windows 10 und wollte den Kernel mit Hyper-V und Guarded Host absichern. Nach der Aktivierung wird mein USB Technotrend 3650CI nicht mehr gefunden. Nach dem Abschalten läuft wieder alles. Bei Technotrend erhält man ja nur den BDA-Treiber und ist auch im System vorhanden, wird aber von dem DVBViewer nicht gefunden.
Lösung?
