MyMovies - Movie info OSD Plugin
amontillado
  • Replies 562
  • Created
  • Last Reply
Top Posters In This Topic
  • amontillado
    171
  • Flowy
    36
  • CiNcH
    29
  • sw4y
    17
Posted Images
Hi amontillado,
I have a problem with the option "Ignore on sort".
These adjustment works directly after activation. But after a restart of the dvbv, it actions no more.
GBWebmaster
Link to comment
I have found the answer all by myself ... ;)
My Problem was the use of a separator in my list. Without a separator it is no problem.
Sorry for the post.
Link to comment
Not without more info.
- Is the mymovies.xml and mymovies_details.xml available in the skin folder
- Is the mymovies.dll (and mymovies_downloader) in DVBViewer applications folder (c;\program files etc)?
- Did you try removing the mymovies.db3 to start with a clean setup (in configuration \ database folder)
- Are the plugin options available, if yes : turn on debug
- What do the osd / osderror logfiles day
- etc.
Link to comment
- etc.
Hi amontillado,
thanks for your response.
- mymovies.xml and mymovies_details.xml is available in folder C:\Program Files\DVBViewer\OSDSkins\X-Skin_v1.1
- mymovies.dll and mymovieS_download.exe are available in folder C:\Program Files\DVBViewer\Plugins
- mymovies.db3 is not available in the folder.
- In generall myseries is working and the x-plugin. different plugsin which are not shown in the options dialog but in the menubar are also working. mymovies is the only one not working.
- see below:
osd
03.04.11 00:03:53.298 TimerDatabase.db3 Created Table: timer
03.04.11 00:03:53.514 MediaDatabase.db3 Created Table: mediadb
03.04.11 00:03:53.784 MediaDatabase.db3 Created Table: bookmarks
03.04.11 00:03:53.943 TVDatabase.db3   Created Table: recordings
03.04.11 00:03:54.467 MusicDatabase.db3 Created Table: artists
03.04.11 00:03:54.816 MusicDatabase.db3 Created Table: albums
03.04.11 00:03:55.231 MusicDatabase.db3 Created Table: genres
03.04.11 00:03:55.449 MusicDatabase.db3 Created Table: paths
03.04.11 00:03:55.773 MusicDatabase.db3 Created Table: songs
03.04.11 00:11:53.317 TVDatabase.db3   Created Table: subtitles
03.04.11 22:13:28.728 SettingsDatabase.db3 Created Table: settings
osderror
03.04.11 00:03:55.977 WindowsInit      Weather window
03.04.11 00:19:47.782 WindowsInit      Weather window
03.04.11 00:22:28.665 WindowsInit      Weather window
03.04.11 00:22:29.035 TWSocketThread   Could not connect: Zugriffsverletzung bei Adresse 004AB043 in Modul 'DVBViewer.exe'. Schreiben von Adresse 00581B04
03.04.11 15:31:37.338 WindowsInit      Weather window
03.04.11 15:32:42.659 WindowsInit      Weather window
03.04.11 15:48:55.402 WindowsInit      Weather window
03.04.11 15:48:55.784 TUCStreamThread  Could not connect, Error: 10038
03.04.11 15:49:47.107 WindowsInit      Weather window
03.04.11 15:51:19.580 WindowsInit      Weather window
03.04.11 15:52:32.155 WindowsInit      Weather window
03.04.11 15:56:55.166 WindowsInit      Weather window
03.04.11 16:02:40.255 WindowsInit      Weather window
03.04.11 16:04:21.497 WindowsInit      Weather window
03.04.11 16:11:10.022 WindowsInit      Weather window
03.04.11 16:11:54.976 WindowsInit      Weather window
03.04.11 16:13:19.100 WindowsInit      Weather window
03.04.11 16:14:21.329 WindowsInit      Weather window
03.04.11 16:14:34.031 Param            running vanilla
03.04.11 16:14:38.477 WindowsInit      Weather window
03.04.11 16:15:13.092 WindowsInit      Weather window
03.04.11 16:17:07.421 WindowsInit      Weather window
03.04.11 16:22:57.627 WindowsInit      Weather window
03.04.11 16:29:30.461 WindowsInit      Weather window
03.04.11 16:30:32.197 WindowsInit      Weather window
03.04.11 16:31:32.530 WindowsInit      Weather window
03.04.11 16:35:05.128 WindowsInit      Weather window
03.04.11 21:24:33.068 WindowsInit      Weather window
03.04.11 21:26:42.119 WindowsInit      Weather window
03.04.11 21:37:43.978 WindowsInit      Weather window
03.04.11 21:41:07.460 WindowsInit      Weather window
03.04.11 21:44:26.073 WindowsInit      Weather window
03.04.11 21:46:06.420 WindowsInit      Weather window
03.04.11 22:10:38.866 WindowsInit      Weather window
03.04.11 22:12:18.788 WindowsInit      Weather window
03.04.11 22:28:12.137 MySeries-IOSDImage Episode image is NOT assigned, please check the myseries.xml for a valid image with controlid:3203
03.04.11 22:28:12.138 MySeries-IOSDImage Episode backgroundimage is NOT assigned, please check the myseries.xml for a valid image with controlid:3233
03.04.11 22:28:12.138 MySeries-IOSDControl Director (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3403
03.04.11 22:28:12.138 MySeries-IOSDControl Actors (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3404
03.04.11 22:28:12.138 MySeries-IOSDControl Option (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3500
03.04.11 22:28:12.138 MySeries-IOSDControl Rating (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3405
03.04.11 22:28:12.138 MySeries-IOSDControl Photography (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3406
03.04.11 22:28:12.138 MySeries-IOSDControl Editor (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3407
03.04.11 22:28:12.138 MySeries-IOSDControl Producer (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3409
03.04.11 22:28:12.138 MySeries-IOSDControl Country(button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3410
03.04.11 22:28:12.139 MySeries-IOSDControl Trailer(button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3411
03.04.11 22:28:12.139 MySeries-IOSDControl Author(button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3412
03.04.11 22:28:12.139 MySeries-IOSDLabelControl Description label is NOT assigned, please check the myseries.xml for a valid label with controlid:3300
03.04.11 22:28:12.139 MySeries-IOSDLabelControl Date label is NOT assigned, please check the myseries.xml for a valid label with controlid:3301
03.04.11 22:28:12.139 MySeries-IOSDLabelControl Genre label is NOT assigned, please check the myseries.xml for a valid label with controlid:3302
03.04.11 22:28:12.139 MySeries-IOSDLabelControl Director label is NOT assigned, please check the myseries.xml for a valid label with controlid:3303
03.04.11 22:28:12.139 MySeries-IOSDLabelControl Actor label is NOT assigned, please check the myseries.xml for a valid label with controlid:3304
03.04.11 22:28:12.139 MySeries-IOSDLabelControl Rating label is NOT assigned, please check the myseries.xml for a valid label with controlid:3305
03.04.11 22:28:12.139 MySeries-IOSDLabelControl Photography label is NOT assigned, please check the myseries.xml for a valid label with controlid:3306
03.04.11 22:28:12.139 MySeries-IOSDLabelControl Editor label is NOT assigned, please check the myseries.xml for a valid label with controlid:3307
03.04.11 22:28:12.139 MySeries-IOSDLabelControl Runtime label is NOT assigned, please check the myseries.xml for a valid label with controlid:3308
03.04.11 22:28:12.139 MySeries-IOSDLabelControl Producer label is NOT assigned, please check the myseries.xml for a valid label with controlid:3309
03.04.11 22:28:12.140 MySeries-IOSDLabelControl Trailer label is NOT assigned, please check the myseries.xml for a valid label with controlid:3311
03.04.11 22:28:12.140 MySeries-IOSDLabelControl Author label is NOT assigned, please check the myseries.xml for a valid label with controlid:3312
03.04.11 22:28:12.140 MySeries-IOSDLabelControl Keypress label is NOT assigned, please check the myseries.xml for a valid label with controlid:3313
03.04.11 22:30:52.452 WindowsInit      Weather window
03.04.11 22:31:57.630 WindowsInit      Weather window
04.04.11 08:12:34.691 WindowsInit      Weather window
04.04.11 08:13:39.202 TUCStreamThread  Session closed, Error: 10053
04.04.11 08:13:39.202 TWSocketThread   Session closed, Error: 10053
04.04.11 09:35:30.544 WindowsInit      Weather window
04.04.11 09:42:12.264 WindowsInit      Weather window
04.04.11 09:51:45.003 WindowsInit      Weather window
04.04.11 10:22:24.032 WindowsInit      Weather window
04.04.11 11:48:02.561 WindowsInit      Weather window
04.04.11 13:22:45.705 WindowsInit      Weather window
04.04.11 13:23:15.333 MySeries-IOSDImage Episode image is NOT assigned, please check the myseries.xml for a valid image with controlid:3203
04.04.11 13:23:15.333 MySeries-IOSDImage Episode backgroundimage is NOT assigned, please check the myseries.xml for a valid image with controlid:3233
04.04.11 13:23:15.333 MySeries-IOSDControl Director (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3403
04.04.11 13:23:15.333 MySeries-IOSDControl Actors (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3404
04.04.11 13:23:15.333 MySeries-IOSDControl Option (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3500
04.04.11 13:23:15.333 MySeries-IOSDControl Rating (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3405
04.04.11 13:23:15.333 MySeries-IOSDControl Photography (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3406
04.04.11 13:23:15.334 MySeries-IOSDControl Editor (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3407
04.04.11 13:23:15.334 MySeries-IOSDControl Producer (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3409
04.04.11 13:23:15.334 MySeries-IOSDControl Country(button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3410
04.04.11 13:23:15.334 MySeries-IOSDControl Trailer(button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3411
04.04.11 13:23:15.334 MySeries-IOSDControl Author(button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3412
04.04.11 13:23:15.334 MySeries-IOSDLabelControl Description label is NOT assigned, please check the myseries.xml for a valid label with controlid:3300
04.04.11 13:23:15.334 MySeries-IOSDLabelControl Date label is NOT assigned, please check the myseries.xml for a valid label with controlid:3301
04.04.11 13:23:15.334 MySeries-IOSDLabelControl Genre label is NOT assigned, please check the myseries.xml for a valid label with controlid:3302
04.04.11 13:23:15.334 MySeries-IOSDLabelControl Director label is NOT assigned, please check the myseries.xml for a valid label with controlid:3303
04.04.11 13:23:15.334 MySeries-IOSDLabelControl Actor label is NOT assigned, please check the myseries.xml for a valid label with controlid:3304
04.04.11 13:23:15.334 MySeries-IOSDLabelControl Rating label is NOT assigned, please check the myseries.xml for a valid label with controlid:3305
04.04.11 13:23:15.335 MySeries-IOSDLabelControl Photography label is NOT assigned, please check the myseries.xml for a valid label with controlid:3306
04.04.11 13:23:15.335 MySeries-IOSDLabelControl Editor label is NOT assigned, please check the myseries.xml for a valid label with controlid:3307
04.04.11 13:23:15.335 MySeries-IOSDLabelControl Runtime label is NOT assigned, please check the myseries.xml for a valid label with controlid:3308
04.04.11 13:23:15.335 MySeries-IOSDLabelControl Producer label is NOT assigned, please check the myseries.xml for a valid label with controlid:3309
04.04.11 13:23:15.335 MySeries-IOSDLabelControl Trailer label is NOT assigned, please check the myseries.xml for a valid label with controlid:3311
04.04.11 13:23:15.335 MySeries-IOSDLabelControl Author label is NOT assigned, please check the myseries.xml for a valid label with controlid:3312
04.04.11 13:23:15.335 MySeries-IOSDLabelControl Keypress label is NOT assigned, please check the myseries.xml for a valid label with controlid:3313
04.04.11 13:26:10.515 WindowsInit      Weather window
04.04.11 13:30:06.693 WindowsInit      Weather window
04.04.11 13:30:54.427 WindowsInit      Weather window
04.04.11 13:31:58.340 WindowsInit      Weather window
04.04.11 13:32:27.871 WindowsInit      Weather window
04.04.11 13:48:25.092 TUCStreamThread  Could not connect, Error: 10038
04.04.11 14:07:10.458 WindowsInit      Weather window
04.04.11 14:41:29.415 WindowsInit      Weather window
04.04.11 14:58:35.811 WindowsInit      Weather window
04.04.11 15:00:09.293 WindowsInit      Weather window
04.04.11 15:12:39.729 WindowsInit      Weather window
04.04.11 15:18:58.135 MySeries-IOSDImage Episode image is NOT assigned, please check the myseries.xml for a valid image with controlid:3203
04.04.11 15:18:58.136 MySeries-IOSDImage Episode backgroundimage is NOT assigned, please check the myseries.xml for a valid image with controlid:3233
04.04.11 15:18:58.136 MySeries-IOSDControl Director (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3403
04.04.11 15:18:58.136 MySeries-IOSDControl Actors (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3404
04.04.11 15:18:58.136 MySeries-IOSDControl Option (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3500
04.04.11 15:18:58.136 MySeries-IOSDControl Rating (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3405
04.04.11 15:18:58.136 MySeries-IOSDControl Photography (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3406
04.04.11 15:18:58.136 MySeries-IOSDControl Editor (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3407
04.04.11 15:18:58.136 MySeries-IOSDControl Producer (button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3409
04.04.11 15:18:58.136 MySeries-IOSDControl Country(button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3410
04.04.11 15:18:58.136 MySeries-IOSDControl Trailer(button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3411
04.04.11 15:18:58.136 MySeries-IOSDControl Author(button) is NOT assigned, please check the myseries.xml for a valid control with controlid:3412
04.04.11 15:18:58.137 MySeries-IOSDLabelControl Description label is NOT assigned, please check the myseries.xml for a valid label with controlid:3300
04.04.11 15:18:58.137 MySeries-IOSDLabelControl Date label is NOT assigned, please check the myseries.xml for a valid label with controlid:3301
04.04.11 15:18:58.137 MySeries-IOSDLabelControl Genre label is NOT assigned, please check the myseries.xml for a valid label with controlid:3302
04.04.11 15:18:58.137 MySeries-IOSDLabelControl Director label is NOT assigned, please check the myseries.xml for a valid label with controlid:3303
04.04.11 15:18:58.137 MySeries-IOSDLabelControl Actor label is NOT assigned, please check the myseries.xml for a valid label with controlid:3304
04.04.11 15:18:58.137 MySeries-IOSDLabelControl Rating label is NOT assigned, please check the myseries.xml for a valid label with controlid:3305
04.04.11 15:18:58.137 MySeries-IOSDLabelControl Photography label is NOT assigned, please check the myseries.xml for a valid label with controlid:3306
04.04.11 15:18:58.138 MySeries-IOSDLabelControl Editor label is NOT assigned, please check the myseries.xml for a valid label with controlid:3307
04.04.11 15:18:58.138 MySeries-IOSDLabelControl Runtime label is NOT assigned, please check the myseries.xml for a valid label with controlid:3308
04.04.11 15:18:58.138 MySeries-IOSDLabelControl Producer label is NOT assigned, please check the myseries.xml for a valid label with controlid:3309
04.04.11 15:18:58.138 MySeries-IOSDLabelControl Trailer label is NOT assigned, please check the myseries.xml for a valid label with controlid:3311
04.04.11 15:18:58.138 MySeries-IOSDLabelControl Author label is NOT assigned, please check the myseries.xml for a valid label with controlid:3312
04.04.11 15:18:58.138 MySeries-IOSDLabelControl Keypress label is NOT assigned, please check the myseries.xml for a valid label with controlid:3313
04.04.11 16:50:32.367 WindowsInit      Weather window
04.04.11 16:54:21.189 Param            running vanilla
04.04.11 16:54:25.487 WindowsInit      Weather window
04.04.11 16:55:14.320 WindowsInit      Weather window
starting DVBViewer in debug mode gives the following in debug
04.04.11 16:58:33.489 Start App        ----------------------------------------
04.04.11 16:58:33.489 Start App        DVBViewer.exe
04.04.11 16:58:33.489 Start App        4.6.0.1
04.04.11 16:58:33.529 SetThreadExecutionState 0x80000001
04.04.11 16:58:33.784 TDVBDevice.InitDevice Unicast Network Device
04.04.11 16:58:33.784 TDVBDevice.InitDevice Unicast Network Device 2
04.04.11 16:58:33.784 Device           Check present
04.04.11 16:58:33.785 CheckDevicespresent start
04.04.11 16:58:33.785 CheckDevicespresent end
04.04.11 16:58:33.997 DevicePath       \\?\hdaudio#func_01&ven_1002&dev_aa01&subsys_00aa0100&rev_1002#5&21cfd9e5&0&0001#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\ehdmioutwave
04.04.11 16:58:33.998 DevicePath       \\?\hdaudio#func_01&ven_10ec&dev_0892&subsys_1458a102&rev_1003#4&2e2c3824&0&0001#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\espdifinwave
04.04.11 16:58:38.404 LoadWindowDefs   Loading WindowDefFile: C:\Program Files\DVBViewer\OSDSkins\X-Skin_v1.1\windowdef.xml
04.04.11 16:58:38.815 Settuner         Start
04.04.11 16:58:38.817 TCMDSocketThread Sessionstarted
04.04.11 16:58:38.817 TUCStreamThread  Sessionstarted
04.04.11 16:58:38.819 Gotstr           OK.
04.04.11 16:58:38.821 TfrmMain Allocate Unicast Network Device
04.04.11 16:58:38.821 Settuner         Found usable hardware
04.04.11 16:58:38.821 TDVBHardware.SetTuner PMT: 96 - SID: 10100 - Freq: 12246 - Type: 1
04.04.11 16:58:38.821 Sendstr          SETTUNER 1	12246	27500	10600	1	1	0	3	256	255	96	10100	1	0	0	24	0	1092	1
04.04.11 16:58:39.200 Gotstr           OK.
04.04.11 16:58:39.201 Sendstr          ADDPID 18
04.04.11 16:58:39.201 Settuner         End
04.04.11 16:58:39.231 Sendstr          ADDPID 255	256	0	96
04.04.11 16:58:39.233 AddAVCodecs      VCodec: CyberLink Video Decoder (PDVD10), ACodec: ffdshow Audio Decoder
04.04.11 16:58:39.249 VCodec           CyberLink Video Decoder (PDVD10)
04.04.11 16:58:39.254 ACodec           ffdshow Audio Decoder
04.04.11 16:58:39.261 EVR              Create
04.04.11 16:58:39.261 EVR              GetDeviceID
04.04.11 16:58:39.261 EVR              GetService
04.04.11 16:58:39.280 EVR              GetService
04.04.11 16:58:39.280 EVR              GetRenderingPrefs
04.04.11 16:58:39.280 EVR              SetRenderingPrefs
04.04.11 16:58:39.280 EVR              SetVideoWindow
04.04.11 16:58:39.280 AddVideoRenderer Add EVR
04.04.11 16:58:39.280 EVR              InitServicePointers
04.04.11 16:58:39.280 EVR              ConfigureMixer
04.04.11 16:58:39.280 EVR              ReleaseServicePointers
04.04.11 16:58:39.280 EVR              Flush
04.04.11 16:58:39.280 EVR              SetMediaType
04.04.11 16:58:39.280 EVR              ReleaseResources
04.04.11 16:58:39.281 EVR              InitServicePointers
04.04.11 16:58:39.281 EVR              ConfigureMixer
04.04.11 16:58:39.281 EVR              ReleaseServicePointers
04.04.11 16:58:39.281 EVR              Flush
04.04.11 16:58:39.281 EVR              SetMediaType
04.04.11 16:58:39.281 EVR              ReleaseResources
04.04.11 16:58:39.282 EVR              ReleaseResources
04.04.11 16:58:39.282 EVR              Flush
04.04.11 16:58:39.282 EVR              InitServicePointers
04.04.11 16:58:39.282 EVR              ConfigureMixer
04.04.11 16:58:39.282 EVR              ReleaseServicePointers
04.04.11 16:58:39.282 EVR              SetMediaType
04.04.11 16:58:39.282 EVR              ProcessMessage RenegotiateMediaType
04.04.11 16:58:39.282 EVR              RenegotiateMediaType
04.04.11 16:58:39.282 EVR              IsMediaTypeSupported
04.04.11 16:58:39.282 EVR              CreateOptimalVideoType
04.04.11 16:58:39.282 EVR              EVROutputRange: 2
04.04.11 16:58:39.282 EVR              VideoTransferMatrix: 1
04.04.11 16:58:39.282 EVR              MediaTypePriority: 0
04.04.11 16:58:39.282 EVR              MediaTypePriority: 90000000
04.04.11 16:58:39.282 EVR              CreateVideoSamples
04.04.11 16:58:39.282 EVR              GetTexturePresentParameters
04.04.11 16:58:39.282 EVR              Videotexture w: 720 x h: 576
04.04.11 16:58:39.282 EVR              CreateD3DSample
04.04.11 16:58:39.283 EVR              CreateD3DSample
04.04.11 16:58:39.283 EVR              GetService
04.04.11 16:58:39.283 EVR              OpenDeviceHandle
04.04.11 16:58:39.283 EVR              GetVideoService
04.04.11 16:58:39.303 EVR              CloseDeviceHandle
04.04.11 16:58:39.362 EVR              ReleaseServicePointers
04.04.11 16:58:39.362 EVR              Flush
04.04.11 16:58:39.362 EVR              SetMediaType
04.04.11 16:58:39.362 EVR              ReleaseResources
04.04.11 16:58:39.362 EVR              InitServicePointers
04.04.11 16:58:39.362 EVR              ConfigureMixer
04.04.11 16:58:39.363 EVR VideoProcessorMode {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}
04.04.11 16:58:39.363 Used Filter 0:   EVR Renderer (Custom)
04.04.11 16:58:39.363 Used Filter 1:   Default DirectSound Device
04.04.11 16:58:39.363 Used Filter 2:   ffdshow Audio Decoder
04.04.11 16:58:39.363 Used Filter 3:   CyberLink Video Decoder (PDVD10)
04.04.11 16:58:39.363 Used Filter 4:   DVB Source
04.04.11 16:58:39.363 EVR              SetAspectRatioMode
04.04.11 16:58:39.363 EVR              SetVideoWindow
04.04.11 16:58:39.437 EVR              ProcessMessage BeginStreaming
04.04.11 16:58:39.438 EVR Scheduler    Start thread
04.04.11 16:58:39.438 EVR              BeginStreaming 0
04.04.11 16:58:39.497 EVR              OnClockStart
04.04.11 16:58:39.497 EVR              StartFrameStep
04.04.11 16:58:39.603 EVR              ProcessMessage Flush
04.04.11 16:58:39.603 EVR              Flush
04.04.11 16:58:39.606 EVR              GetService
04.04.11 16:58:39.606 EVR              OpenDeviceHandle
04.04.11 16:58:39.606 EVR              GetVideoService
04.04.11 16:58:39.613 EVR              CloseDeviceHandle
04.04.11 16:58:39.613 EVR              ProcessMessage ENDOFSTREAM
04.04.11 16:58:39.613 EVR              CheckEndOfStream
04.04.11 16:58:39.613 EVR              CheckEndOfStream EC_COMPLETE
04.04.11 16:58:39.613 EVR              ProcessMessage RenegotiateMediaType
04.04.11 16:58:39.613 EVR              RenegotiateMediaType
04.04.11 16:58:39.613 EVR              IsMediaTypeSupported
04.04.11 16:58:39.613 EVR              CreateOptimalVideoType
04.04.11 16:58:39.613 EVR              EVROutputRange: 2
04.04.11 16:58:39.613 EVR              VideoTransferMatrix: 1
04.04.11 16:58:39.613 EVR              MediaTypePriority: 0
04.04.11 16:58:39.613 EVR              MediaTypePriority: 90000000
04.04.11 16:58:39.613 EVR              SetMediaType
04.04.11 16:58:39.613 EVR              ReleaseResources
04.04.11 16:58:39.613 EVR              Flush
04.04.11 16:58:39.614 EVR              CreateVideoSamples
04.04.11 16:58:39.614 EVR              ReleaseResources
04.04.11 16:58:39.614 EVR              Flush
04.04.11 16:58:39.614 EVR              GetTexturePresentParameters
04.04.11 16:58:39.614 EVR              Videotexture w: 544 x h: 576
04.04.11 16:58:39.614 EVR              CreateD3DSample
04.04.11 16:58:39.875 EVR              ProcessMessage RenegotiateMediaType
04.04.11 16:58:39.875 EVR              RenegotiateMediaType
04.04.11 16:58:39.875 EVR              IsMediaTypeSupported
04.04.11 16:58:39.875 EVR              CreateOptimalVideoType
04.04.11 16:58:39.875 EVR              EVROutputRange: 2
04.04.11 16:58:39.875 EVR              VideoTransferMatrix: 1
04.04.11 16:58:39.875 EVR              MediaTypePriority: 0
04.04.11 16:58:39.875 EVR              MediaTypePriority: 90000000
04.04.11 16:58:39.875 EVR              SetMediaType
04.04.11 16:58:39.915 EVR Scheduler    New PerFrameInterval: 200000
04.04.11 16:58:40.957 EVR              SetAspectRatioMode
04.04.11 16:58:41.248 EVR              SetAspectRatioMode
04.04.11 16:58:41.428 EVR Scheduler    nextdelta: -4804
04.04.11 16:58:41.428 EVR Scheduler    Dropped Frame
04.04.11 16:58:41.550 EVR              SetAspectRatioMode
04.04.11 16:58:42.076 EVR              SetAspectRatioMode
04.04.11 16:58:42.588 EVR              SetAspectRatioMode
04.04.11 16:58:42.786 EVR Scheduler    nextdelta: -174902
04.04.11 16:58:42.786 EVR Scheduler    Dropped Frame
04.04.11 16:58:43.123 EVR              SetAspectRatioMode
04.04.11 16:58:46.923 Gotstr           SIG 77
04.04.11 16:58:47.749 EVR Scheduler    nextdelta: -2919
04.04.11 16:58:47.749 EVR Scheduler    Dropped Frame
MySeries is working perfectly fine, same for X-Plugin. But the MyMovies is not shown under options.
Regards and thanks again.
dacula
Link to comment
I;ve uploaded a test version please try this one:
www.amontillado.nl/mymovies/MyMovies.dll
then check the osd/osderror.log (should entries like 'MM Test'...)
After that please try what happens if you copy sqlite3.dll and mediainfo.dll in the plugin directory. (after testing you can remove the sqlite3.dll again from the plugin dir)
Link to comment
Didn't do anything.
04.04.11 16:57:41.660 WindowsInit Weather window
04.04.11 16:58:33.884 Param running vanilla
04.04.11 16:58:38.458 WindowsInit Weather window
04.04.11 17:04:02.184 WindowsInit Weather window
04.04.11 21:31:45.170 WindowsInit Weather window
04.04.11 21:33:43.441 WindowsInit Weather window
04.04.11 21:36:00.168 WindowsInit Weather window
Those are the entries from osderror log. osd log doesnt have any entries. i copied the mediainfo in plugins, the sqllite3 into plugins, nothing showed or anything.
Link to comment
that is extremly weird.. because i've added standard DVBViewer logwrites in the init stage, so before the plugin actually does anything at all.
At the moment i'm clueless...
could you try an older version to see if that works again.
Link to comment
Maybe you need to enable debug logging for those log outputs? I'm not quite sure now, but you could try to run DVBViewer with parameter -debug.
Link to comment
thanks for the update.
I'll change the instructions accordingly (to be honest, I thought there was allready a mediainfo.dll in the application root after a fresh install of DVBViewer, never checked that).
Link to comment
I've built in a small check to see if mediainfo.dll is in the root, and if not it will look if it is in the plugins dir. I prefer that it uses the one thats in the root so that it always uses the same as DVBViewer/recording service uses... but if its not there mymovies can use the one in the plugin folder (which comes with the mymovies package)
Edited by amontillado
Link to comment
hi,
bei mir funktioniert mymovies mit DaemonTools nicht richtig.
Wenn ich über das OSD "MediaCenter"-> "Videos" eine .iso öffne, muss ich nur 2x das Windows-Fenster "userAccountControl" mit "ja" bestätigen und DVBV verhält sich dann, als hätte ich eine normale DVD eingelegt.
Wenn ich über OSD "MyMovies"-> einen Film auswähle, muss ich ebenfalls 2x das Windows-Fenster "userAccountControl" mit "ja" bestätigen, aber dann popt das DaemonToolsFenster hoch (siehe Anhang) und die .iso wurde (im Gegensatz zu obiger Variante) von DaemonTools auch nicht in von "Device 0: [G] gemountet.
Muss ich die .iso-Dateien irgendwie speziell benennen oder so?? (zur Zeit etwa so abgespeicher: "FilmeOrdner"->"FilmNameOrdner"->folder.jpeg, folder_original.jpg,FILM_NAME.iso,"BackdropsOrdner", info.txt)
Edited by viewy
Link to comment
I will have a look at this somewhere this week, you're not the first to mention it but I don't actually have any .iso's (or daemon toolds) so I first need to get one to figure out what has changed there.
Link to comment
Hi.
I've got some questions (and maybe suggestions) regarding the downloader. First: The downloader is really great and works way better than filminfopics which sadly is quite outdated today. :)
Added: MID is now editable in MyMovies Movie editor to allow for convient way to change the ID if the wrong movie was found
I don't understand this point from the changelog. What ID is the MID, given that there are already fields for TMDB ID and IMDB ID. What ID can be inserted here?
What aspects does your downloader use to find a movie from tmdb? The foldername like filminfopics? Sometimes I have movies, that are not found. For example I have a movie, named after the german title, but it's only entered in tmdb for the english title. I'd like the tool to download all the stuff and info for the english version and only edit the title to the german title afterwards... what do I need to change to convince the downloader to do so?
Is there anyway to just add the movie manually, enter the tmdb id (and maybe IMDB id if that is used somewhere ;)) and let the downloader update all the other infos? That would be quite a nice addition, I guess.
//Edit:
Ok, I managed to find the "Downloader" Button in the mymovie settings and fiddled arround with that a bit. But it's still strange and not really deterministic, if TMDB finds a movie or not... the website search finds the movie for exact the same title which seems not to be working for the api. In those cases it would be great to have and TMDB-ID field in the downloader to override all searching stuff and just download the infos and images for a given ID. :)
Edited by Moses
Link to comment
This was actually implemented for filminfopics, filminfopics would use the MID as the Id for tmdb (field for tmdb is filled by the downloaders and since its difficult to spot if that was manually changed we decided to have an extra id for it.) But this will be probably reworked in the next version to make it more usefull.
Currently it uses the foldername. The TMDB Api looks for the title in title fields as well as in the alternative title fields. So even if the download language is english, "Der Pate" will always be found (and saved as The Godfather).
It will download only the info in the set download langauge. In a next version it will also download it in the default (english) if there is no info in the regular download language. But what you can allready do is set the download language to english and change the title later manually (just edit the movie and change the title there).
Currently no, but the temp version I posted ago allready has an option it that it will save unfound movies to the DB, you can then look for the title via the OSD (if you use categories you can find all unmatched movies in the unknown categories folder).
As written above, the MID field is actually meant for what you just suggested, and something like it will possibly be added to the downloader in a next version.
//edit
could you give some examples of movies which it doesn't find (as well as the foldername). I want to check if its an problem of the API or of the downloader.
Link to comment
Ok, today they seem to be working. Problem yesterday was for example with "Belles zauberhafte Welt". But today it's found by the downloader... I think it had also something to do with me playing on the language settings... but I'm not sure about that.
A problem still remains: It's close to impossible to get the correct entry for "Der Graf von Monte Christo". ;)
Edited by Moses
Link to comment
I had a quick look and did see a small error, mabye you can quickly test this version http://amontillado.n...ies_0.02.xx.zip.
Ps. i did not test it at all because of the lack of daemon tools and an .iso, so if it doesn't work you'll have to wait.
Ps2. It should work with virtualclone (but it should also have worked with daemon toold :) ).
Hello,
have the same problem with iso files and vcdmount. no automount. tried your last version but without success. external mounted iso files are played correct
Edited by derloe
Link to comment
I can select the two possiblities from the OSD menu (Download movie info). And, I can also force the correct one by putting the year in the folder name.
But regardless of that, the next version will allow for manually setting the TMDB id so if the above doesn't work you will have to wait a short while
Link to comment
Do you support replacing underscores with blanks?
Yes it replaces underscores with blanks before looking for the title at tmdb.
Doesn't it work for you ?
Link to comment
Seems that TMDB has some problems today :( (Internal Server Error, Bad Gateway a.s.o.)
[Edit]
At least the web frontend works again. But the downloader does not find anything
Start
Setting, -config folder :C:\ProgramData\CMUV\DVBViewer\
Setting, -sql           :C:\Program Files\DVBViewer\sqlite3.dll
start
>> Looking for new titles in the following paths <<
\\fritz.box\WD-7500AACExternal-05
>> The following new directories/titles have been found <<
Directory    : \\fritz.box\WD-7500AACExternal-05\KAUFHAUS_COP\
Search title : KAUFHAUS COP
No movie match found, try changing the directory name
Directory    : \\fritz.box\WD-7500AACExternal-05\SOLOMON_KANE\
Search title : SOLOMON KANE
Directory    : \\fritz.box\WD-7500AACExternal-05\AVATAR\
Search title : AVATAR
Directory    : \\fritz.box\WD-7500AACExternal-05\THE_POLAR_EXPRESS\
Search title : THE POLAR EXPRESS
Directory    : \\fritz.box\WD-7500AACExternal-05\ALL_INCLUSIVE\
Search title : ALL INCLUSIVE
Directory    : \\fritz.box\WD-7500AACExternal-05\ANGELS_AND_DEMONS\
Search title : ANGELS AND DEMONS
Directory    : \\fritz.box\WD-7500AACExternal-05\DEATH_AT_A_FUNERAL\
Search title : DEATH AT A FUNERAL
Directory    : \\fritz.box\WD-7500AACExternal-05\VAMPIRES_SUCK\
Search title : VAMPIRES SUCK
Directory    : \\fritz.box\WD-7500AACExternal-05\INCEPTION\
Search title : INCEPTION
Directory    : \\fritz.box\WD-7500AACExternal-05\UNDISPUTED III\
Search title : UNDISPUTED III
Directory    : \\fritz.box\WD-7500AACExternal-05\THE_SOCIAL_NETWORK\
Search title : THE SOCIAL NETWORK
end
Link to comment
I just gave Media Center Master a shot. I don't think that it is necessary to reinvent the wheel. Your plugin is able to import the MCM meta data, right? Why do we need another downloader if a pretty sophisticated solution already exists?
Link to comment
[Edit]
Start
start
end
Just tried these, it found them all. Maybe you were unlucky and tried it at a moment the api site was down?
Btw. I also thought for a long time that we didn't need another downloader... thats why I never made one. But the questions posted/pm-ed/email indicate differently. It is for many easier if it all comes in one package. And this does allow me to for example implement an autoupdate feature and the abbility to change the title (and redownload) from osd.
Link to comment
Indeed. It works now.
I think it is just a matter of promotion. MCM is quite a complete and well maintained tool. Maybe we should just write a simple manual for it all.
Link to comment
I have done a quick test now with Media Center Master and importing the meta data with your MyMovies plugin. So I created a folder with 3 movie folders inside:
'CASINO_ROYALE' (DVD structure)
'UNDISPUTED III' (MKV)
'WHAT HAPPENS IN VEGAS' (ISO)
Everything worked out of the box, including correct file paths.
Link to comment
isn't life beautifull sometimes :biggrin:
Good to hear, I actually build the support for importing MCM data without ever having seen MCM, so good to hear that it works.
In my opinion MCM is the better downloader, but I will keep the mymovies downloader for now. Mainly since I do like the fact that I can control it quite easily from the OSD and well.. it's there now ;)
Link to comment
Indeed it is cool to have something like that.
MCM is a cool way of managing the movies and their meta data however (in case wrong or no meta data is found for a given title, MCM has more sources to chose from and may have better algorithms to find titles...).
Link to comment
  • 3 weeks later...
Da meine englische Rechtschreibung nicht gerade die Beste ist, schreibe ich das hier lieber auf deutsch. Ich hoffe das geht in Ordnung.
Bis jetzt benutze ich noch Mediaportal als Media Center. Aber da der TV Support einfach nur die Hölle ist, versuche ich jetzt den DVBViewer als Alternative. Da kommt dein Plugin gerade recht ;)
Ich habe jetzt nicht alle 35 Seiten durchgelesen und weiß nicht ob die Vorschläge schon genannt wurden bzw. ob du sie schon beantwortet hast.
Wird der Importer noch erweitert um die Datenbanken von anderen Tools zu importieren?
Media Center Master sagt mir nicht besonders zu und der integrierte Downloader ist nicht besonders flexibel. Da ich ja eh schon eine fertige Filmdatenbank in Moving Pictures habe würde ich diese gerne importieren.
Falls es die Arbeit erleichtern sollte, es gibt ein Tool, dass bereits die Daten der einzelnen Filme aus der Moving Pictures Datenbank in die jeweiligen Filmordner exportiert.
Hier der Link: http://forum.team-mediaportal.com/moving-pictures-284/app-copy-artwork-details-movie-folder-71649/
Danach hat man das Cover(folder.jpg), Hintergrundbild(backdrop.jpg) und eine .nfo Datei(movie.nfo) mit den Filminfos in der jeweiligen Ordnern. Die .nfo Datei ist XBMC kompatibel.
So würdest du dann auch gleich das XBMC für den Import unterstützen!
Das würde wahrscheinlich nicht nur mir den Umstieg auf auf MyMovies erleichtern ;)
Hier ist der Aufbau einer dieser .nfo Dateien beschrieben: http://wiki.xbmc.org/?title=Import_-_Export_Library#Movies
Es wäre auch noch schön wenn man die Alterfreigabe der Filme irgendwo eintragen könnte.
Wäre es außerdem möglich das Plugin für den Skin Memo09 anzupassen?
http://www.DVBViewer.tv/forum/topic/37582-skin-memo09/
Ich kenne mich leider mit programmieren usw. überhaupt nicht aus und weiß nicht wie schwer es ist, dass alles umzusetzen. Aber wenn du das hinbekommen würdest wäre das wirklich klasse!
Mfg Kirak
Link to comment
Let's try to keep it in english here guys.. non german have it difficult enough here :).
As Tjod allready mentioned, there is allready import tool for xmbc, next to mediamaster, filminfopics and the downloader.. so quite some alternatives ;).
If I have some time to spare I might be willing to implement the .nfo, seems straight forward enough, but don't expect it to soon since all my time is taken by a new plugin.
The skin thing is something you could do yourself quite easily with the skineditor.
Link to comment
