aramrahgozar Posted January 17, 2016 Posted January 17, 2016 Hi I have a problem with some transponders.some transponders have not signal in DVBViewer but same transponders have good and strong signal in dvbdream. TP for DVBViewer and dvbdream is same. Thanks Quote
Tjod Posted January 17, 2016 Posted January 17, 2016 Is the transponder list in DVBViewer up to date? The channel scan in DVBViewer is only able to detect DVB-S2 channels if all parameter in the transponder list is correct. TransEdit is the tool to edit transponder list. 1 Quote
aramrahgozar Posted January 17, 2016 Author Posted January 17, 2016 Yes , it is, also i use same TP for viewer and dream.i guess may be dream works better in some TP , is it true? Quote
Derrick Posted January 17, 2016 Posted January 17, 2016 ..no problem here. Your 0130.ini might be outdated. 1 Quote
aramrahgozar Posted January 18, 2016 Author Posted January 18, 2016 ..no problem here. Your 0130.ini might be outdated. in first post i said TP is update and if TP isn't update, why dream can tune and recieve.(TP viewer and dream are same , copied) Quote
aramrahgozar Posted January 18, 2016 Author Posted January 18, 2016 There is no problem in transponder file.seem problem is player! Quote
Derrick Posted January 18, 2016 Posted January 18, 2016 post the ini file and a support.zip please. Quote
aramrahgozar Posted January 18, 2016 Author Posted January 18, 2016 Thanks dvbdream 13E TP.zip DVBViewer 13E TP.zip Quote
Derrick Posted January 18, 2016 Posted January 18, 2016 your list doesn't comply to the DVBViewer standard. The indicator DVB-S2 is missing. 1 Quote
aramrahgozar Posted January 18, 2016 Author Posted January 18, 2016 your list doesn't comply to the DVBViewer standard. The indicator DVB-S2 is missing. didn't work! i downloaded tp for DVBViewer pro & DVBViewer for technisat from satfinder, but any didn't recieve signal in 10971. ex: 14=10971,H,29700,23,S2,8PSK Quote
aramrahgozar Posted January 18, 2016 Author Posted January 18, 2016 Try this one from the DVBViewer Setup DVB-S_0130.ini oh my f... it worked.i don't know what happen but thank you so much. i used viewer always and now can hope to continue THANKS Quote
