Delphi Posted July 14, 2019 Author Posted July 14, 2019 I can't reproduce the error. I need some more information: Please PM me your XgrabDMS.ini file Additionally, please answer my questions: On 6/28/2019 at 1:26 AM, Delphi said: If you are using Xepg: does that connect? Quote
bounguine Posted July 21, 2019 Posted July 21, 2019 Hi! There is a problem, when testing import: Processing: C:\Program Files (x86)\DVBViewer\xmltv.xml XMLTV reader Engine: OXml SAX Copyright: Ondřej Pokorný, Kluug.net This software uses OXml by Kluug.net. URL: http://www.kluug.net xml version=1.0 encoding=utf-8 ERROR TYPE: Unknown Importing EPG EXCEPTION MESSAGE---EAccessViolation:Access violation at address 006BD0CD in module 'Xepg.exe'. Read of address 00000000 Error on importing EPG ERROR: Unknown Importing EPG Quote
Delphi Posted July 21, 2019 Author Posted July 21, 2019 Please PM me your Config.ini file (resides in the Xepg Data Folder, link in Xepg main window). Or you can now try: Use the EasyXml SAX engine instead of OXml SAX Upgrade Xepg to latest version (0.7.4.0) if not allready done 2 hours ago, bounguine said: Processing: C:\Program Files (x86)\DVBViewer\xmltv.xml If possible, store your file xmltv.xml in the Xepg Data Folder.- Quote
bounguine Posted July 21, 2019 Posted July 21, 2019 2 hours ago, Delphi said: Please PM me your Config.ini file (resides in the Xepg Data Folder, link in Xepg main window). Did it. Changed to EasyXml SAX: Processing: C:\Program Files (x86)\DVBViewer\xmltv.xml XMLTV reader Engine: EasyXML SAX xml version="1.0" encoding="utf-8" -- Fatal Error on line: 20580, col: 14 Access violation at address 006BD0CD in module 'Xepg.exe'. Read of address 00000000 ERROR TYPE: File is not a legal XML file Contact your XMLTV provider to correct the error EXCEPTION MESSAGE---XepgException:Process Aborted Error on importing EPG ERROR: File is not a legal XML file Contact your XMLTV provider to correct the error Quote
Delphi Posted July 21, 2019 Author Posted July 21, 2019 Congratulation! You have posted the biggest xmltv files I have ever seen (xmltv.xml - 92MB and geniptv.xml - 241MB). At least in theory they should not be a problem for Xepg. They are both too big to open in my browsers in order to test well-formedness. I am currently having Xepg importing xmltv.xml using the Microsoft MSXML DOM engine. Takes a LONG time! You can try that yourself. If it can eat the file with no error message we know that the file is well-formed. The max file size for MSXML DOM is about 100MB. In any case I think an in-depth test is needed, so please additionally PM me the following files: From Xepg Data Folder: Pairings.xml From DVBViewer Configuration Folder: channels.dat Quote
Delphi Posted July 21, 2019 Author Posted July 21, 2019 The file xmltv.xml proved well-formed. I will do some more testing. Quote
Delphi Posted July 22, 2019 Author Posted July 22, 2019 (edited) Try this one <link deleted> The file only contains Xepg.exe, just replace that in your current installation of Xepg. Edited July 24, 2019 by Delphi Quote
Delphi Posted July 24, 2019 Author Posted July 24, 2019 (edited) @bounguine: Good that it works now. There is a new pre-release here <link deleted> This one additionally displays a message when pairing orphants are found in the file Pairings.xml in case of a channel pairing. A pairing orphant is a DVBViewer channel that exists in the Pairings.xml but not in the DVBViewer channel list. Your shipped Pairings.xml had 704 orphants! I advice you to do a channel pairing. Edited September 4, 2019 by Delphi Quote
allanlee Posted July 26, 2019 Posted July 26, 2019 On 7/15/2019 at 4:16 AM, Delphi said: I can't reproduce the error. I need some more information: Please PM me your XgrabDMS.ini file Additionally, please answer my questions: Will PM you in 5 minuts. Xepg works. It connects to DMS and imports xml epg (generated by EPG Center without error. Quote
Delphi Posted July 26, 2019 Author Posted July 26, 2019 I see no errors in your XgrabDMS.ini file. Noone has ever reported such an error. 1) Check once more that the UserName, Password and Port are entered correct. You can see what they are in Xepg, use those. 2) You have IP=127.0.0.1. This means that XgrabDMS.exe should run on the same pc as the DMS. Does it? Quote
allanlee Posted July 26, 2019 Posted July 26, 2019 1 minute ago, Delphi said: 1) Check once more that the UserName, Password and Port are entered correct. You can see what they are in Xepg, use those. Yes I'm using the exact same username & password. If I delete XgrabDMS.ini and let XgrabDMS prompt me again to enter these information, "Test Connection" returns "Success" but once I clicked OK the 404 error come. 4 minutes ago, Delphi said: 2) You have IP=127.0.0.1. This means that XgrabDMS.exe should run on the same pc as the DMS. Does it? Yes exactly. Quote
Delphi Posted July 26, 2019 Author Posted July 26, 2019 I have no idea on what's going on, sorry. However, I am working on an upgrade, comming soon. Maybe that one works for you. Quote
allanlee Posted July 26, 2019 Posted July 26, 2019 6 minutes ago, Delphi said: I have no idea on what's going on, sorry. However, I am working on an upgrade, comming soon. Maybe that one works for you. Thank you. Looking forward to the new version and will test out. Hope that works. :-) Quote
Delphi Posted July 27, 2019 Author Posted July 27, 2019 @allanlee: https://www.DVBViewer.tv/forum/topic/59663-xepg/?do=findComment&comment=476631 Try to set IP=localhost in stead of 127.0.0.1 Quote
allanlee Posted July 27, 2019 Posted July 27, 2019 1 minute ago, Delphi said: Try to set IP=localhost in stead of 127.0.0.1 Same 404 Quote
allanlee Posted July 27, 2019 Posted July 27, 2019 27 minutes ago, Delphi said: @allanlee: https://www.DVBViewer.tv/forum/topic/59663-xepg/?do=findComment&comment=476631 Try to set IP=localhost in stead of 127.0.0.1 I used another PC in the same intranet, also 404. And find this in DMS svcdebug.log (http://127.0.0.1:8089/api/getconfigfile.html?file=svcdebug.log&download=1) 28.07.19 02:12:02.690 TBaseProcess HandleAPI Error 3 Quote
Delphi Posted July 27, 2019 Author Posted July 27, 2019 I don't know what HandleAPI Error 3 means. One of the first things XgrabDMS does is to download the channellist: http://<username>:<password>@127.0.0.1:8089/api/getchannelsxml.html?tuner=1 Try to enter this into your browsers url field. Replace <username>:<password> with your real ones of course. Quote
allanlee Posted July 27, 2019 Posted July 27, 2019 7 minutes ago, Delphi said: http://<username>:<password>@127.0.0.1:8089/api/getchannelsxml.html?tuner=1 Try to enter this into your browsers url field. Replace <username>:<password> with your real ones of course. Seems no problem. <channels> <root name="DVB-T2"> <group name="mediacorp"> <channel nr="0" name="Channel 5" EPGID="882624369328130" flags="24" ID="3713217898687627266"> <tuner tnrtype="2" group="0" flags="24" freq="538000" symb="0" LOF="0" PMT="200" satmod="132" AVformat="18" FEC="0" pol="2" OrbPos="5000" Tone="0" EPGFlag="0" DiSEqCVal="0" DiSEqC="0" alang="eng" APID="230" VPID="220" TSID="1" TelePID="0" NID="8894" SID="2" PCRPID="220"/> </channel> <channel nr="1" name="Suria" EPGID="882624369328132" flags="24" ID="3713217898700734468"> <tuner tnrtype="2" group="0" flags="24" freq="538000" symb="0" LOF="0" PMT="400" satmod="132" AVformat="18" FEC="0" pol="2" OrbPos="5000" Tone="0" EPGFlag="0" DiSEqCVal="0" DiSEqC="0" alang="may" APID="430" VPID="420" TSID="1" TelePID="0" NID="8894" SID="4" PCRPID="420"/> </channel> <channel nr="2" name="Channel 8" EPGID="882624369393667" flags="24" ID="3713217902989148163"> <tuner tnrtype="2" group="0" flags="24" freq="554000" symb="0" LOF="0" PMT="300" satmod="132" AVformat="18" FEC="0" pol="2" OrbPos="5000" Tone="0" EPGFlag="0" DiSEqCVal="0" DiSEqC="0" alang="ZHO" APID="330" VPID="320" TSID="2" TelePID="0" NID="8894" SID="3" PCRPID="320"/> </channel> <channel nr="3" name="Vasantham" EPGID="882624369393669" flags="24" ID="3713217903002255365"> <tuner tnrtype="2" group="0" flags="24" freq="554000" symb="0" LOF="0" PMT="500" satmod="132" AVformat="18" FEC="0" pol="2" OrbPos="5000" Tone="0" EPGFlag="0" DiSEqCVal="0" DiSEqC="0" alang="TAM" APID="530" VPID="520" TSID="2" TelePID="0" NID="8894" SID="5" PCRPID="520"/> </channel> <channel nr="4" name="CNA" EPGID="882624369524752" flags="24" ID="3713217911598809104"> <tuner tnrtype="2" group="0" flags="24" freq="570000" symb="0" LOF="0" PMT="600" satmod="132" AVformat="18" FEC="0" pol="2" OrbPos="5000" Tone="0" EPGFlag="0" DiSEqCVal="0" DiSEqC="0" alang="eng" APID="631" VPID="620" TSID="4" TelePID="0" NID="8894" SID="16" PCRPID="620"/> </channel> <channel nr="5" name="Channel U" EPGID="882624369524753" flags="24" ID="3713217911605297169"> <tuner tnrtype="2" group="0" flags="24" freq="570000" symb="0" LOF="0" PMT="700" satmod="132" AVformat="18" FEC="0" pol="2" OrbPos="5000" Tone="0" EPGFlag="0" DiSEqCVal="0" DiSEqC="0" alang="zho" APID="730" VPID="720" TSID="4" TelePID="0" NID="8894" SID="17" PCRPID="720"/> </channel> <channel nr="6" name="okto (HD)" EPGID="882624369524754" flags="24" ID="3713217911611850770"> <tuner tnrtype="2" group="0" flags="24" freq="570000" symb="0" LOF="0" PMT="800" satmod="132" AVformat="18" FEC="0" pol="2" OrbPos="5000" Tone="0" EPGFlag="0" DiSEqCVal="0" DiSEqC="0" alang="eng" APID="830" VPID="820" TSID="4" TelePID="0" NID="8894" SID="18" PCRPID="820"/> </channel> </group> </root> </channels> Quote
Delphi Posted August 3, 2019 Author Posted August 3, 2019 Quote XgrabDMS 0.2.0.0 is available The changelog is contained in the zip file along with detailed help files. Quote
Delphi Posted August 4, 2019 Author Posted August 4, 2019 Quote Xepg 0.7.4.1 is available Fixed the access violation bug reported earlier. Quote
wuffzack Posted September 4, 2019 Posted September 4, 2019 (edited) Hello, I discovered a shortcoming in xepg. It ignores the presence of multiple display names per channel id. For example: <channel id="ARD.de"> <display-name>Das Erste DE</display-name> <icon src="https://cdn-static.ams3.cdn.digitaloceanspaces.com/picons/daserstehd.png" /> </channel> <channel id="ARD.de"> <display-name>Das Erste FHD DE</display-name> <icon src="https://cdn-static.ams3.cdn.digitaloceanspaces.com/picons/daserstehd.png" /> </channel> <channel id="ARD.de"> <display-name>Das Erste HD DE</display-name> <icon src="https://cdn-static.ams3.cdn.digitaloceanspaces.com/picons/daserstehd.png" /> </channel> In this case, xepg will only create one EPG channel like "Das Erste HD DE" with ARD.de as the source. It should create three. This would greatly ease up channel pairing, as it could be done fully automatic. Edited September 4, 2019 by wuffzack Quote
wuffzack Posted September 4, 2019 Posted September 4, 2019 I tried to rewrite the xml file to match more the xmltv format published here http://wiki.xmltv.org/index.php/XMLTVFormat, but it didn't help. In the example below, xepg only finds the first channel "Das Erste DE". <channel id="ARD.de"> <display-name>Das Erste DE</display-name> <display-name>Das Erste HD DE</display-name> <display-name>Das Erste FHD DE</display-name> <icon src="https://cdn-static.ams3.cdn.digitaloceanspaces.com/picons/daserstehd.png" /></channel> Quote
Delphi Posted September 4, 2019 Author Posted September 4, 2019 (edited) 8 hours ago, wuffzack said: In this case, xepg will only create one EPG channel like "Das Erste HD DE" with ARD.de as the source. Yes, Xepg takes only the first one and ignores the rest. Mostly due to this (from xmltv.dtd): Quote List the most canonical / common ones first and the most obscure names last. 8 hours ago, wuffzack said: It should create three. Who said that? 8 hours ago, wuffzack said: This would greatly ease up channel pairing, as it could be done fully automatic. Maybe in your case. However, it's not possible to fully automate channel pairing for all Xepg users. Some human interaction is needed in most cases. The auto pairing usually finds most of the pairings. The remaining must be done manually. Should not be that hard considering all the navigating, filtering and searching options available. ------------------------------ Let's assume that all display names are stored and searched for in the auto pair process (possible ofcourse). This would lead to the following drawbacks/questions: 1) A display name like "2" (without the quotes) would probably lead to too many hits which you would have to answer no to. 2) How should all those display names be displayed in the xml tree (left pane)? 3) I would have to rewrite the Xepg code in quite many places. I conclude that such a change would just complicate things for most users and only be a benefit for few users. For now I will not do it, sorry. Only if massive requests pop up I might consider. Edited September 4, 2019 by Delphi Quote
Delphi Posted September 4, 2019 Author Posted September 4, 2019 @wuffzack Do you have the channels Das Erste DE Das Erste FHD DE Das Erste HD DE as DVBViewer channels? If yes, you should use EPG sharing: Quote
wuffzack Posted September 4, 2019 Posted September 4, 2019 @Delphi Yes, I have Das Erste DE Das Erste FHD DE Das Erste HD DE as DVBViewer channels. So, this is supposed to work? I have checked "Search for EPG sharing channels". Only 1 match is found, not 3. It doesn't seem to work for me. In the upper half, I have unticked all but "exact match", because all channels are actually exact matches to the display names. Quote
wuffzack Posted September 4, 2019 Posted September 4, 2019 <channel id="ARD.de"> <display-name>Das Erste DE</display-name> <icon src="https://cdn-static.ams3.cdn.digitaloceanspaces.com/picons/daserstehd.png" /> </channel> <channel id="ARD.de"> <display-name>Das Erste FHD DE</display-name> <icon src="https://cdn-static.ams3.cdn.digitaloceanspaces.com/picons/daserstehd.png" /> </channel> <channel id="ARD.de"> <display-name>Das Erste HD DE</display-name> <icon src="https://cdn-static.ams3.cdn.digitaloceanspaces.com/picons/daserstehd.png" /> </channel> This is supposed to work, too? Because there are many similar constructs in the xmltv file, and they all do not work, only the last of them is found and matched. Quote
wuffzack Posted September 4, 2019 Posted September 4, 2019 2 hours ago, Delphi said: Who said that? Maybe in your case. However, it's not possible to fully automate channel pairing for all Xepg users. Some human interaction is needed in most cases. I think this would only be logical to add all display names. Assume you have a channel "bla". With the display names "bla hd", "bla sd", "bla fhd". Currently you pick one display name (sometimes the first, sometimes the last, depending how the xml file is structured) and put it in the left xmltv tree view. Two are ignored. This is quite unlogical IMHO. If you add three display names, then 1.) automatic exact matching would work, if corresponding DVBViewer channels exist. Otherwise one (more or less) random match will match. 2.) For other users, there should not be much difference. At least I believe so. But you could make this change optional with a tiny checkbox. Disabled by default ? Quote
Delphi Posted September 4, 2019 Author Posted September 4, 2019 35 minutes ago, wuffzack said: 1.) automatic exact matching would work, if corresponding DVBViewer channels exist. Otherwise one (more or less) random match will match. 2.) For other users, there should not be much difference. At least I believe so. But you could make this change optional with a tiny checkbox. Disabled by default I have never in my more than 10 years work with xmltv seen that situation. I will not change the code just for this very rare case. Note, that you can execute as many auto pair sessions as you want with different settings. Something like following should find the missing ones: A bit of creativity is allowed Quote
wuffzack Posted September 4, 2019 Posted September 4, 2019 What is the "Search for EPG sharing channels" option supposed to do? Should it look into alternate "display-name" values? For me, it doesn't seem to do anything. Being a programmer myself, I tried to be creative to automate the process and modify the Pairings.xml file myself, but I can't easily find a way to get the DVBViewer channel numbers. Quote
wuffzack Posted September 4, 2019 Posted September 4, 2019 22 minutes ago, Delphi said: I have never in my more than 10 years work with xmltv seen that situation. I will not change the code just for this very rare case. Well, the many IPTV providers which exist today didn't exist for the last 10 years. And they all have xmltv files formatted this way, corresponding to their m3u files. Quote
wuffzack Posted September 4, 2019 Posted September 4, 2019 23 minutes ago, wuffzack said: Being a programmer myself, I tried to be creative to automate the process and modify the Pairings.xml file myself, but I can't easily find a way to get the DVBViewer channel numbers. It is the EPGID, which I can easily get with the media server api. Maybe I can make a very simple tool which just creates a pairings.xml file myself and all will be well. Quote
Delphi Posted September 4, 2019 Author Posted September 4, 2019 (edited) EPG Sharing is one xmltv ID (e.g. id="ARD.de") paired to more than one EPGID (DVBViewer channel). It's all in the help file 56 minutes ago, wuffzack said: What is the "Search for EPG sharing channels" option supposed to do? Even if a matching (assuming settings as in the screenshot) DVBViewer channel is found (Das Erste DE) it continues to search the DVBViewer channel list for additional matches for pairing. In your case it should offer you to additionally pair Das Erste FHD DE and Das Erste HD DE to id="ARD.de". All 3 channels will get the same epg. Isn't that what you want? 54 minutes ago, wuffzack said: Well, the many IPTV providers which exist today didn't exist for the last 10 years. And they all have xmltv files formatted this way, corresponding to their m3u files. I see. If it is of general interest I could have a look at it. Please upload one or more xmltv and m3u files (zip them). You can PM me the links if you don't want them public. Edited September 4, 2019 by Delphi Quote
VinoRosso Posted September 5, 2019 Posted September 5, 2019 I found a small cosmetic problem, it is not possible to enter https URLs as grabber source, it always shows an error message. If i enter a http URL it works, although my server always redirects http to https. Quote
Delphi Posted September 5, 2019 Author Posted September 5, 2019 (edited) For many years I have had support for https downloads on my todo list. I don't consider the problem just cosmetic. I never found the time to implement it because noone requested it...untill now. I plan to use the Indy library for the http/https stuff instead of WinINet, which I am currently using. Hope you can live with things as they are, for now. Edited September 5, 2019 by Delphi Quote
Delphi Posted September 6, 2019 Author Posted September 6, 2019 @VinoRosso and others: Xepg.zip Supports https downloads. Just replace the contained Xepg.exe in your Xepg installation. Quote
VinoRosso Posted September 7, 2019 Posted September 7, 2019 I considered it cosmetic because it did already work with https ? My server forces a 301 redirect for all http URLs to https. This means your implementation followed the redirect and used https to download the files. I just could not enter https in the UI. PS: I did not try the new version yet Quote
Delphi Posted September 9, 2019 Author Posted September 9, 2019 On 9/7/2019 at 10:21 PM, VinoRosso said: I just could not enter https in the UI You can with the new version, and it works. Quote
allanlee Posted September 18, 2019 Posted September 18, 2019 Tested XgrabDMS2, same problem as before. ERROR: MESSAGE: Exception:Failed to load channellist. EIdHTTPProtocolException:HTTP/1.1 404 Not Found Application will terminate. After entering username & password, the "test connection" is successful. What could I do to help solve this? Thank you very much in advance. Quote
Delphi Posted September 18, 2019 Author Posted September 18, 2019 The only thing I can think of is: Do you sit behind a proxy server? I yes, you must ensure that local calls (e.g localhost) bypasses the proxy server. Quote
