elle2310 Posted April 27, 2013 Posted April 27, 2013 Dear Community, well I'm quite new in the scene here and don't see the difference between the TT-S2-3600 and the TT-S2-4600. I would like to know, which of these devices is the better one, where are the differences and if it's worth buying a device (S2-4600) which is more expensive. Liebe Community, ich bin ziemlich neu hier und will mir einen TechnoTrend Gerät zum Fernsehschauen zulegen, im Moment schwanke ich zwischen dem TT-connect S2-3600 und dem TT-connect S2-4600. Welches Gerät würdet ihr mir empfehlen, ich kann im Moment keinen technischen Unterschied zwischen den beiden Geräten sehen. Gibt es welche? Quote
Griga Posted April 27, 2013 Posted April 27, 2013 The TT S2 3600 is an original (classic) TechnoTrend product, the TT S2 4600 is a relabeled TeVii S660 resp. S662 OEM box. Quote
elle2310 Posted April 27, 2013 Author Posted April 27, 2013 (edited) Hello Griga, thanks for the answer, which device would you recommend me? Are there differences? Edited April 27, 2013 by elle2310 Quote
Griga Posted April 27, 2013 Posted April 27, 2013 I've given you keywords. Search the web for user experience. Or this forum with the Google site search: site:DVBViewer.tv keyword(s) Something that I've found: http://www.amazon.de/review/R3FCX7VXTMZNOM But always consider that user ratings depend on personal experience, expectations, requirements and the (system) conditions under which a device and its driver runs. That's why reports can be quite contradictory... Quote
