How to stop recording service ?
Manouchehr
I am trying to install DVB pro on Windows 10 I receive this error !
How I can stop recording ?
Please explain clearly . I am 70 years old and not a gig !
Click in the arrow (in the windows task bar) and make a right click on the Recording Service icon.
And select "stop Recording Service" the icon should turn Gray.
After the installation you have to start the Recording service there or restart windows.
Hello
There i not such thing in the task bar . Once I uninstalled and installed DVB pro again , I receive the error
This message is not from the DVBViewer or its set-up.
It is from Windows and means likely you don't have the right to execute this program.
This doesn't happen in usual DVBViewer installation even if you run the DVBViewer in a liniment user.
Are you using some sort of program whit listing solution? If you don't know what this is and you aren't in a cooperate environment (work notebook) it is likely not the case.
Try starting the DVBViewer one time with admin rights. Right click on it and select run as administrator. Does this fix the problem?
